(2018-04-02, 10:57)Steffen Wrote: [ -> ]in the LDRAW wiki, the image "Construction worker.png" appears broken when accessing the page
https://wiki.ldraw.org/index.php?title=BlueBrick
via https. When using http, the image looks fine:
http://wiki.ldraw.org/index.php?title=BlueBrick
To cure this, I suggest that we end the dual presence of both http and https this way:
* make https the default
* make any access to a http address a forwarding to its https counterpart
Image looks fine to me on both. But I'll permanently redirect http to https.
P.S. Thanks for all the Wiki work lately.
This seems to be browser-dependent. Chrome seemingly blocks an http image inside a https page.
When I try
https://wiki.ldraw.org/wiki/Web-Based_Applications
in Chrome 65.0.3325.181 on Windows, the image in the "under construction" box is broken.
Yeah, I took nearly the full Easter Monday to roar through it
I'm still not finished yet, and of course there still are lots of things to do,
but I found it sleeping a little sleep and thought it could get some cleanup.
I will continue
My goal during that is: keep as simple as possible. Make easy to understand for newbies.
Yup, just confirmed. Chrome's console explicitly states that it did not load the http images
because they were embedded inside a https page:
attachment=3155]
This means: our server somehow still defaults to serving by http.
It should be changed to serve everything (including images) by https.
Maybe the answer is very simple, check
https://www.mediawiki.org/wiki/Manual:&#...r/en#HTTPS
I suggest that we configure the server like this:
(a) MediaWiki gets configured to run in https mode exclusively. No http mix etc. at all.
(b) Apache could be
configured to rewrite every http URL into a https URL (so existing links will still work).
This will make things clear and simple and at the same time 100% https as far as I can see.
(2018-04-03, 17:54)Steffen Wrote: [ -> ]> Chrome seemingly blocks an http image inside a https page.
(b) Apache could be configured to rewrite every http URL into a https URL (so existing links will still work).
The 2 suggestions above were already implemented but this issue is fixed. The image path was set to a value that wasn't the default and it hardcoded the non-https URL.
