Full Version: Nexo Knights shields
Hi guys
I begin to creat this shield -->
https://forums.ldraw.org/thread-7354-pos...l#pid28341
Now I read here --->
http://www.ldraw.org/cgi-bin/ptdetail.cg...385pe0.dat
the disscussion about the barcode on the shield.
Now the question: Should I draw the shield now with or without the code?
Since I have created a template for the edge and the part in LDPC, because I want to draw more shields, it's not a problem either with or without code.
Regards
Johann
I stand on my position: since images are widely spread, there is no reason to remove the barcode from LDraw model!
I agree.
(2018-03-27, 19:15)Magnus Forsberg Wrote: [ -> ]I agree.
Yes, the barcode should be drawn. There are plenty of internet resources that already make this information public.
Apparently the three-digit identifiers listed at spyrius.org are used within the Nexo Knights app, so have some official blessing. Since there are over 300 known patterns, the existing LDraw patterned parts nomenclature is not going to work for part 22385 (Tile 3 x 2 with Angled End). So for the Nexo Knights Powers patterned versions of this part, I propose using that three-digit identifier, like 22385pNNN.dat. If patterned versions of this part appear for other themes, the existing nomenclature will apply.
(2018-04-02, 9:52)Chris Dee Wrote: [ -> ]
I just have upload 6 shields, and there are more
Should i rename then and upload a new version or do you this in PT Chris?
Edit: Forget the question. I have seen you have already done it.
