I downloaded the AIOI 2018-01 and installed by accepting all the defaults.
LDView opens and renders Cafe Corner correctly.
However when I open LDCAD I get the following:
LDCAD 1.6a Error
can't open file 'C:\Users\Public\Documents\LDraw\complete.zip' (error 2:the system cannot find the file specified.)
[OK]
I have checked that file path and the file does not exist.
Any ideas? This is on a fresh PC that hasn't had any LDraw applications installed on it before. Operating System is Windows 10 1703 64-Bit.
(2018-03-20, 17:46)Simon Denscombe Wrote: [ -> ]I downloaded the AIOI 2018-01 and installed by accepting all the defaults.
LDCAD 1.6a Error
[OK]
I'll investigate. Please upload your log file under c:\Windows\LDraw
(2018-03-20, 20:04)Willy Tschager Wrote: [ -> ] (2018-03-20, 17:46)Simon Denscombe Wrote: [ -> ]LDCAD 1.6a Error
If complete.zip was at that location at one point (temporary?) and ldcad is using "C:\Users\Public\Documents\LDraw\" as the default library location given in LDCad.cfg. It could result in this message when complete zip is removed later. As complete.zip has priority over loose files when first checking for a library in the given folder.
(2018-03-21, 9:28)Simon Denscombe Wrote: [ -> ] (2018-03-20, 20:04)Willy Tschager Wrote: [ -> ]I'll investigate. Please upload your log file under c:\Windows\LDraw
Setup Log.txt attached.
Thanks for the file. I was able to track the bug and it should work now. I'll upload version2 which also comes with LeoCAD 18-02 and LDCad 1.6b in the coming days.
(2018-03-21, 11:20)Willy Tschager Wrote: [ -> ] (2018-03-21, 9:28)Simon Denscombe Wrote: [ -> ]Setup Log.txt attached.
I've got the same issue, I was wondering if the updated AiOI was available some where yet?
(2018-04-23, 22:17)End Unsure Wrote: [ -> ] (2018-03-21, 11:20)Willy Tschager Wrote: [ -> ]Thanks for the file. I was able to track the bug and it should work now. I'll upload version2 which also comes with LeoCAD 18-02 and LDCad 1.6b in the coming days.
The release candidate for version 2 can be found here:
http://www.holly-wood.it/tmp/LDraw_AIOI_...bit_v2.exe
(2018-04-24, 8:05)Willy Tschager Wrote: [ -> ] (2018-04-23, 22:17)End Unsure Wrote: [ -> ]I've got the same issue, I was wondering if the updated AiOI was available some where yet?
Seems to work for me now.
Thanks.
Thank you very much sir, I knew it must be done but I wasn't able to find it.
