Full Version: Couple more part requests
I'd try to do these myself but my time to work on these things is very limited. Anyway:
87079pr0012 Tile 2 x 4 with Brickheadz Seasonal Calendar print
32606 Friends Accessories Flower with 7 Thick Petals and Pin
(2018-03-06, 15:43)Orion Pobursky Wrote: [ -> ]I'd try to do these myself but my time to work on these things is very limited. Anyway:
Hi Orion
I would try this one:
Where can I get a picture from the front side?
Quote:Where can I get a picture from the front side?
Should be good enough... (Photoshoped from https://www.youtube.com/watch?v=xLQ5bC-nsRk )
I would have a try with the flower if I had the part (or many photos...)
(2018-03-06, 19:21)Johann Eisner Wrote: [ -> ]
Hi Orion
You can take 87079pz1 as an example, there is already a sub part for the Brickheadz logo on the left.
Also, as I’m working on all Brickheadz parts, I can do it myself if you prefer, just let me know.
(2018-03-06, 19:41)Philippe Hurbain Wrote: [ -> ]
Photos are easy. I'll try to have them up shortly.
I have got the flower, I can get you some photos. I thought I have seen it on digital bricks, but I can't find it now...
(2018-03-06, 21:53)Orion Pobursky Wrote: [ -> ]
(2018-03-06, 19:41)Philippe Hurbain Wrote: [ -> ]Should be good enough... (Photoshoped from https://www.youtube.com/watch?v=xLQ5bC-nsRk )
[attachment=3107][attachment=3108][attachment=3109][attachment=3110][attachment=3111]
(2018-03-07, 0:08)Orion Pobursky Wrote: [ -> ]
(2018-03-06, 21:53)Orion Pobursky Wrote: [ -> ]Photos are easy. I'll try to have them up shortly.
Thanks for the photos. One thing not totally clear from them: what's the sequence of petal height? Is there a left-right symmetry somewhere?
(2018-03-07, 9:00)Philippe Hurbain Wrote: [ -> ]Thanks for the photos. One thing not totally clear from them: what's the sequence of petal height? Is there a left-right symmetry somewhere?
There's one petal that stands for itself, Orion did not make a picture of that one.
It is slanted in a way. If this petal faces you, it is slanted upwards from right to left.
Then it continues (clockwise): Low, High, Low, High, Low High.
so three, different petals.
Thanks for the photo.
(2018-03-06, 21:19)Damien Roux Wrote: [ -> ]
(2018-03-06, 19:21)Johann Eisner Wrote: [ -> ]Hi Orion
I think, you mean 87079pz0.
This is a very good template.
If you do not care, then I'll do the work.
Regards Johann
(2018-03-07, 11:25)Johann Eisner Wrote: [ -> ]
(2018-03-06, 21:19)Damien Roux Wrote: [ -> ]You can take 87079pz1 as an example, there is already a sub part for the Brickheadz logo on the left.
Regards Johann
87079pz0, sorry.
You can do the job, of course!
Thanks, Gerald!
Here's the slanted petal
[attachment=3113]
Progressing...
After a long night....
http://www.ldraw.org/cgi-bin/ptdetail.cg...079pz4.dat
You guys rock. Thanks!
The part that was created and is currently in the LDraw library is WRONG. The actual (real life) part does not have such high differences between the petals.
Check the official images from Lego:
https://www.lego.com/cdn/product-assets/...182260.jpg
etc.
There are some very subtle height differences between the petals, and some slanting, but this model shows a difference of more than the petal thickness! This makes it unusable because it generates collisions where in real life none exist.
(2018-03-09, 13:52)Philippe Hurbain Wrote: [ -> ]...done! http://www.ldraw.org/cgi-bin/ptdetail.cg.../32606.dat
please rework to match the real item. see my previous post in thread.
(2021-04-06, 13:03)Luke Arts Wrote: [ -> ]The part that was created and is currently in the LDraw library is WRONG. The actual (real life) part does not have such high differences between the petals.
etc.
Problem is that I have no better reference and I don't want to modify it for a result that could prove wrong too... Maybe you could turn off collision detection on this one?
32606 flower has been updated. Many thanks to Magnus who provided dimentional information and quick checked my draft.
https://www.ldraw.org/cgi-bin/ptdetail.c.../32606.dat
Hey guys,
thanks a lot for your work on 32606. The new shape looks perfect on that page: https://library.ldraw.org/tracker/5830
However, when I download it, the file is still the old version. I've tried to contact an admin, but I haven't received an answer in more than 3 weeks. Can someone confirm if the version being downloaded is just the old version of the part? Thanks a lot Smile
(2024-09-15, 22:39)Sébastien TURREL Wrote: [ -> ]Hey guys,
No need to download it, it is an official part of Update 2024-05. If you've got the latest version of the library on your disc:
https://library.ldraw.org/updates?latest
it is part of it.
Are you, perchance, using Stud.io? They're library is usually out of sync from the latest release. There are tutorial to import the updated part, please search the forum.
(2024-09-16, 13:18)Orion Pobursky Wrote: [ -> ]Are you, perchance, using Stud.io? They're library is usually out of sync from the latest release. There are tutorial to import the updated part, please search the forum.
I am using it, but not for this case Smile I am just pressing the download button on the top left here: https://library.ldraw.org/tracker/5830
Can you confirm that I am not crazy please ahah
(2024-09-16, 15:39)Sébastien TURREL Wrote: [ -> ]I am using it, but not for this case Smile I am just pressing the download button on the top left here: https://library.ldraw.org/tracker/5830
I downloaded the part from the download link, zip link, and from the latest complete.zip, they are identical
I then downloaded the 2018-02 update and compared the part from that file to the one downloaded above and they are different.
This leads me to believe that the file is indeed up to date in our system and there has to be some sort of Stud.io weirdness happening on your end.
(2024-09-16, 17:00)Orion Pobursky Wrote: [ -> ]I downloaded the part from the download link, zip link, and from the latest complete.zip, they are identical
The model was updated in 2024-06-30.
I am not using Stud.io here Smile
I am opening the model with LDview. The model from 2024-06-30 is well displayed on the right of the page https://library.ldraw.org/tracker/5830 but I am not getting the same model when downloading it, I am getting the model from 2021-04-10.
I can make a video.
(2024-09-16, 21:23)Sébastien TURREL Wrote: [ -> ]The model was updated in 2024-06-30.
I can make a video.
I'm still confused. There's definitely something weird going on. Maybe a video would help me spot where the problem is.
(2024-09-16, 21:30)Orion Pobursky Wrote: [ -> ]I'm still confused. There's definitely something weird going on. Maybe a video would help me spot where the problem is.
This is my video: https://youtu.be/2wlJIVzSdpY :)
I am not yet a professional streamer ahah but I hope you will get my problem! Thanks in advance.
(2024-09-17, 21:25)Sébastien TURREL Wrote: [ -> ]This is my video: https://youtu.be/2wlJIVzSdpY :)
My hunch is that you still have the old subparts in your library (32606s01 and 32606s02), so when you download the new model, it is referencing the old subparts. Is it better if you use the "Download zip file" button instead?
N. W. Perry hit the nail on the head. What's happening is that LDView is reusing the old subparts it previously download. I recommend you clear out the folder that LDView stores unofficial parts (the path is in the preferences).
That said, this part is now official. I recommend you do what I do and download the latest complete.zip, delete your old library, and unzip complete into it's place.
(2024-09-17, 21:51)Orion Pobursky Wrote: [ -> ]N. W. Perry hit the nail on the head. What's happening is that LDView is reusing the old subparts it previously download. I recommend you clear out the folder that LDView stores unofficial parts (the path is in the preferences).
Okay thanks. I was kinda lost.
I'm still not having what I want but I think this is just a matter of time Smile
(2024-09-17, 21:39)N. W. Perry Wrote: [ -> ]My hunch is that you still have the old subparts in your library (32606s01 and 32606s02), so when you download the new model, it is referencing the old subparts. Is it better if you use the "Download zip file" button instead?
Thanks a lot <3
