(2018-03-06, 19:41)Philippe Hurbain Wrote: [ -> ]Quote:Where can I get a picture from the front side?
Should be good enough... (Photoshoped from https://www.youtube.com/watch?v=xLQ5bC-nsRk )
I would have a try with the flower if I had the part (or many photos...)
Photos are easy. I'll try to have them up shortly.
I have got the flower, I can get you some photos. I thought I have seen it on digital bricks, but I can't find it now...
(2018-03-07, 0:08)Orion Pobursky Wrote: [ -> ] (2018-03-06, 21:53)Orion Pobursky Wrote: [ -> ]Photos are easy. I'll try to have them up shortly.
Thanks for the photos. One thing not totally clear from them: what's the sequence of petal height? Is there a left-right symmetry somewhere?
(2018-03-07, 9:00)Philippe Hurbain Wrote: [ -> ]Thanks for the photos. One thing not totally clear from them: what's the sequence of petal height? Is there a left-right symmetry somewhere?
There's one petal that stands for itself, Orion did not make a picture of that one.
It is slanted in a way. If this petal faces you, it is slanted upwards from right to left.
Then it continues (clockwise): Low, High, Low, High, Low High.
so three, different petals.
(2018-03-06, 21:19)Damien Roux Wrote: [ -> ] (2018-03-06, 19:21)Johann Eisner Wrote: [ -> ]Hi Orion
I would try this one:
87079pr0012 Tile 2 x 4 with Brickheadz Seasonal Calendar print
You can take 87079pz1 as an example, there is already a sub part for the Brickheadz logo on the left.
Also, as I’m working on all Brickheadz parts, I can do it myself if you prefer, just let me know.
I think, you mean 87079pz0.
This is a very good template.
If you do not care, then I'll do the work.
Regards Johann
(2018-03-07, 11:25)Johann Eisner Wrote: [ -> ] (2018-03-06, 21:19)Damien Roux Wrote: [ -> ]You can take 87079pz1 as an example, there is already a sub part for the Brickheadz logo on the left.
Regards Johann
87079pz0, sorry.
You can do the job, of course!
(2021-04-06, 13:03)Luke Arts Wrote: [ -> ]The part that was created and is currently in the LDraw library is WRONG. The actual (real life) part does not have such high differences between the petals.
Check the official images from Lego:
https://www.lego.com/cdn/product-assets/...182260.jpg
etc.
There are some very subtle height differences between the petals, and some slanting, but this model shows a difference of more than the petal thickness! This makes it unusable because it generates collisions where in real life none exist.
Problem is that I have no better reference and I don't want to modify it for a result that could prove wrong too... Maybe you could turn off collision detection on this one?
