2018-02-08, 18:59
Hey,
it took me a while to fix the !TEXMAP SPHERICAL rendering in LDPE... here it is
Changelog:
(3 new features and 4 bug fixes)
What will the next release 0.8.44 deliver? Usability improvements, major changes to the "BFC / TEXMAP" render mode.
When you install/extract LDPE on Windows you will find your LDPE configuration files under
{drive}\Users\{user}\AppData\Roaming\LDPartEditor
It is not recommended to use the "update.bat" script when you installed LDPE via the setup file.
Manually install the new version instead.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Changelog:
- ...check an option during setup which associates *.dat files to LDPartEditor.
- ...benefit from an enhanced surface creation by Lines2Pattern.
- ...see the poles correctly on !TEXMAP SPHERICAL.
- Ytruder still generated triangles sometimes when it should generate quads.
- Switching the manipulator via keyboard (translate, rotate, scale) "cleared" the current transformation.
- Selecting a color for the font in Txt2dat did not work. Letters were always rendered in black.
- Fixed a rare NullPointerException which occured while closing the application.
- Download the zip-Archive
- On windows, double-click "LDPartEditor.exe" to start LDPE.
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
