(2018-02-08, 1:26)Michael Horvath Wrote: [ -> ]Where can I find the latest, most complete list of LDraw colors? I've noticed that the different editors do not share one common list.
Here are some (incomplete) lists I've found:
http://wiki.ldraw.org/index.php?title=Us...ison_Chart
http://www.ldraw.org/article/547.html
LDConfig.ldr
lg_colors.lst
Thanks.
The only official source of LDraw colors is LDConfig.ldr. Anything that isn’t in line with that list is out of date or not official.
Indeed you are correct.
There are a few discrepencies however:
334 lg_gold_chrome
998 lg_medium_orange
999 lg_undefined
These are missing from LDConfig.ldr.
(2018-02-08, 23:59)Michael Horvath Wrote: [ -> ]Indeed you are correct.
334 lg_gold_chrome
999 lg_undefined
334 is present in LDConfig.ldr. The latest version can be found at
http://www.ldraw.org/article/547.html and was also distributed with parts update 2017-01.
[url=http://www.ldraw.org/article/547.html][/url]
(2018-02-09, 9:30)Chris Dee Wrote: [ -> ] (2018-02-08, 23:59)Michael Horvath Wrote: [ -> ]Indeed you are correct.
334 lg_gold_chrome
999 lg_undefined
334 is present in LDConfig.ldr. The latest version can be found at http://www.ldraw.org/article/547.html and was also distributed with parts update 2017-01.
Oops! I forgot that 334 was misnamed in LGEO, but that it was later fixed.
I did notice however that LDCad has an color 382 (and possibly others that I did not check for) which is not in LDConfig.ldr.
(2018-02-09, 12:25)Michael Horvath Wrote: [ -> ]I did notice however that LDCad has an color 382 (and possibly others that I did not check) which is not in LDConfig.ldr.
Not really. LDCad defaults (not a good idea imho) to give the possibility to use "dithered colors", not in LDConfig.ldr. To disable this, as it can be misleading (and clobbers colors palettes), Prefs -> Ldraw -> Calculate missing dithered -> disabled and Prefs -> Ldraw -> Calculate missing transparent -> disabled
(2018-02-09, 12:54)Philippe Hurbain Wrote: [ -> ] (2018-02-09, 12:25)Michael Horvath Wrote: [ -> ]I did notice however that LDCad has an color 382 (and possibly others that I did not check) which is not in LDConfig.ldr.
I am creating scripts to switch back and forth between L3P, LDView and LDCad color palettes, and these dithered colors are causing me problems.
LDCad seems to assign ldMat382 to parts in a model I created in MLCad. I don't understand why it does that, since I did not set this color manually.
(2018-02-12, 2:07)Michael Horvath Wrote: [ -> ]LDCad seems to assign ldMat382 to parts in a model I created in MLCad. I don't understand why it does that, since I did not set this color manually.
If you're talking about datsville, building_024_andershouse.ldr is using color 382. So even if its not in the LDConfig.ldr pallette the missing color willl be gray and yellow dithered.
Below is how I handle those colors, the actual RGB is (a+b)/2 of the two source colors.
might be useful for your script:
if (calcMissingDitheredMaterial)
int cnt=0;
TLDMaterial *a, *b, *mat;
for (int i=256; i<512; i++)
mat=findMaterial(i);
if (mat==NULL || mat->isMissing())
a=findMaterial((i-256) >> 4);
b=findMaterial((i-256) & 0x0F);
if (a!=NULL && b!=NULL)
if (mat==NULL)
mat=new TLDMaterial(i, a, b);
addMaterial(mat);
else
mat->reInit(i, a, b);
++cnt;
LOG_REPORT1(log, LL_Progress, logMsg_LDraw_doneCalcDitherMat, cnt);
(2018-02-12, 18:15)Roland Melkert Wrote: [ -> ] (2018-02-12, 2:07)Michael Horvath Wrote: [ -> ]LDCad seems to assign ldMat382 to parts in a model I created in MLCad. I don't understand why it does that, since I did not set this color manually.
int cnt=0;
if (mat==NULL)
addMaterial(mat);
else
++cnt;
My mistake. I changed the color in building_024_andershouse.ldr to light gray.
