2018-01-27, 11:46
2018-01-27, 13:06
I am working on a draft for 24855
Will upload here later
2018-01-28, 7:37
(2018-01-27, 13:06)Gerald Lasser Wrote: [ -> ]I am working on a draft for 24855
Thanks a lot!
2018-01-31, 8:50
2018-02-02, 13:41
(2018-01-31, 8:50)Gerald Lasser Wrote: [ -> ]Here is the first draft:
http://www.ldraw.org/cgi-bin/ptdetail.cg.../24885.dat
Many thanks! I will follow it up in part tracker
2018-02-11, 4:56
Request part 32607, Plant Plate, Round 1 x 1 with 3 Leaves.
https://www.bricklink.com/v2/search.page?q=32607
Thanks
Thanks
2018-02-11, 10:26
(2018-02-11, 4:56)Orion Pobursky Wrote: [ -> ]Request part 32607, Plant Plate, Round 1 x 1 with 3 Leaves.We already have good photos from top/bottom, but could you provide some photos from side and front?
Thanks
2018-02-11, 16:33
(2018-02-11, 10:26)Philippe Hurbain Wrote: [ -> ](2018-02-11, 4:56)Orion Pobursky Wrote: [ -> ]Request part 32607, Plant Plate, Round 1 x 1 with 3 Leaves.We already have good photos from top/bottom, but could you provide some photos from side and front?
Thanks
Can do. I’ll have those uploaded soon.
2018-02-11, 17:01
(2018-02-11, 16:33)Orion Pobursky Wrote: [ -> ]Can do. I’ll have those uploaded soon.Don't forget to add standard parts (eg. plates) nearby (in the same focus plane) for scaling!
2018-02-11, 17:28
(2018-02-11, 17:01)Philippe Hurbain Wrote: [ -> ](2018-02-11, 16:33)Orion Pobursky Wrote: [ -> ]Can do. I’ll have those uploaded soon.Don't forget to add standard parts (eg. plates) nearby (in the same focus plane) for scaling!
Ok. I just noticed that someone requested this part before me so I’m going to merge this thread with that one
2018-02-12, 14:54
(2018-02-11, 17:01)Philippe Hurbain Wrote: [ -> ]Don't forget to add standard parts (eg. plates) nearby (in the same focus plane) for scaling!I suspect that placed at 45° in a corner it covers more or less a 2x2 plate. Would be nice to have a photo in this configuration, seen exactly from top (and from far away to avoid parallax distortion). Or a scan using a flat bed scanner...
2018-02-13, 5:53
Thanks
More pictures can be found on New Elementary website: http://www.newelementary.com/2017/12/new...32607.html
2018-02-13, 8:59
(2018-02-13, 5:53)Vincent M Wrote: [ -> ]More pictures can be found on New Elementary website: http://www.newelementary.com/2017/12/new...32607.htmlYes I know about this excellent website, but what I need is orthogonal views to be able to derive dimensions/curvature of leaves.
2018-02-14, 1:11
(2018-02-11, 10:26)Philippe Hurbain Wrote: [ -> ]We already have good photos from top/bottom, but could you provide some photos from side and front
[attachment=3061][attachment=3062][attachment=3063][attachment=3064]
2018-02-14, 10:59
Progressing... Now on PT! http://www.ldraw.org/cgi-bin/ptdetail.cg.../32607.dat
2018-02-15, 21:55
(2018-02-14, 10:59)Philippe Hurbain Wrote: [ -> ]Progressing... Now on PT! http://www.ldraw.org/cgi-bin/ptdetail.cg.../32607.dat
I just noticed this on the PT. Thanks!.
P.S If you edit a post it doesn't show up in the unread posts list.
2018-02-16, 19:08
Thanks a lot for your work!
