2018-01-23, 20:36
this release is mainly a critical bug fix, but it includes one handy feature: You can now open *.dat files from the Windows file explorer.
Changelog:
(1 new feature and 3 bug fixes)
What will the next release 0.8.43 deliver? An improved version of Lines2Pattern, bug fixes.
When you install/extract LDPE on Windows you will find your LDPE configuration files under
{drive}\Users\{user}\AppData\Roaming\LDPartEditor
It is not recommended to use the "update.bat" script when you installed LDPE via the setup file.
Manually install the new version instead.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
- Select a *.dat file
- Open the context menu
- Select "Open with"
- Select "Choose another app"
- Browse for LDPartEditor.exe
Changelog:
- ...open *.dat files with LDPartEditor from the Windows file explorer ("Open with..." and select LDPartEditor.exe).
- Fixed a rare but critical undo/redo bug.
- Fixed a synchronization bug between the text and 3D editor.
- Fixed a bug which could freeze the text editor.
- Download the zip-Archive
- On windows, double-click "LDPartEditor.exe" to start LDPE.
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 versionIf it's not a 64-bit version, you'll get a message that looks like:
