Try to draw the torso.
Is there any image on the backside?
(2018-01-17, 17:37)Johann Eisner Wrote: [ -> ]Try to draw the torso.
https://youtu.be/GSH-clqe8TI?t=4m14s
Jangbricks videos are generally high quality and a good source for a lot of things...
(2018-01-17, 17:59)Philippe Hurbain Wrote: [ -> ] (2018-01-17, 17:37)Johann Eisner Wrote: [ -> ]Try to draw the torso.
Ah, OK. I could always screenshot some frames from that movie and use texture mapping then
I actually saw that you can wrap textures around a minifig head too?
(2018-01-17, 18:46)Jaco van der Molen Wrote: [ -> ]I actually saw that you can wrap textures around a minifig head too?
"Yes, but"...
- You can use cylindrical mapping but it needs an unwrapped image you generally don't have.
- Or you can do planar mapping of a photo. Problem is that since the head is rounded, it's pretty difficult to get a photo that doen't have bright spots here or there...
Version 1 is done.
What should be the correct name?
Which file name should the torso get for the part tracker?
![[Image: 640x297.jpg]](https://bricksafe.com/files/technicbasics/60180/60180%20Torso%20white2.png/640x297.jpg)
Here the .dat file -->
Minifig Torso for Set 60180
(2018-01-18, 18:35)Johann Eisner Wrote: [ -> ]Version 1 is done.
![[Image: 640x297.jpg]](https://bricksafe.com/files/technicbasics/60180/60180%20Torso%20white1.png/640x297.jpg)
Here the .dat file --> Minifig Torso for Set 60180
Oh, great. Thanks so much. This will absolutely do for the instructions I am making.
