2018-01-11, 22:16
Hey,
this took me so long to fulfil this whishlist...
But now there is a breaking change: You can launch / install LDPE under Windows like any other application
Changelog:
(1 new feature and 2 bug fixes)
What will the next release 0.8.42 deliver? Bug fixes, new features (e.g. open *.dat files from the Windows Explorer in LDPE with "Open with...").
When you install/extract LDPE on Windows you will find your LDPE configuration files under
{drive}\Users\{user}\AppData\Roaming\LDPartEditor
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues for this release. There is a potential risk of data loss.
It is not recommended to use the "update.bat" script when you installed LDPE via the setup file.
Manually install the new version instead.
System Requirements:
Minimum System Requirements:
Changelog:
- ...launch an LDPartEditor executable under Windows / install it with a setup file (breaking change).
- Colour table (OS: Windows) - The scroll on mouse over, in the list view, only worked when the pointer was over the slider. Not when it was over the list.
- The primitive area disappeared sometimes, because a paint event cleared the canvas.
- Download the zip-Archive
- On windows, double-click "LDPartEditor.exe" to start LDPE.
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
