2018-01-04, 11:10
Hey,
I am just on the release train... arriving at the next station :)
This version also includes some minor changes which could provide a solution to Santeri Piippo's problems under Ubuntu Mate.
Changelog:
(5 new features and 5 bug fixes)
What will the next release 0.8.41 deliver? An LDPE executable and setup file for Windows users.
System Requirements:
Minimum System Requirements:
Changelog:
- ...unscale something without losing current origin/orientation (double click on the selected subfile -> hold Ctrl and click on "Move selected subfile to manipulator").
- ..."Move selected subfile to manipulator" and it keeps subfile scaling when doing so.
- ...choose more practical icon sizes (range 12px ... 32px).
- ...benefit from more "clean" tabs (Snap/Selection/BG-Image) on the 3D editor.
- ...benefit from little performance improvements.
- Unificator deleted some surfaces from the unified mesh.
- Edger2 created wrong condlines if there is a slighty mismatch.
- "Move Manipulator to Subfile" warped the manipulator if there was shearing involved.
- Colour table, linux-only: The scroll on mouse over, in the list view, only worked when the pointer was over the slider. Not when it was over the list. I will try to fix this under Windows with the next release!
- It was possible to activate "Move Adjacent Data" on the selection tab for subfiles, but it had no effect (it should not be possible to activate the button in this case!)
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
