2017-12-29, 11:05
I wanted to release this version in 2018, but I completed it earlier... why should I wait?
Changelog:
(6 new features and 7 bug fixes)
What will the next release 0.8.40 deliver? More features for subfile manipulation / bug-fixes.
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a SlantingMatrixProjector tool to generate shear matrices.
- ...save all your user settings in a file, and restore it when you want to (screenshot).
- ...restore your 3D view settings when you completed a PartReview.
- ...use ALT + UP/DOWN to move a line up and down in the text editor.
- ...see a progress bar when downloading files from the PT for PartReview.
- ...set the coplanarity threshold (Tools... -> Options...).
- Colour palette: The window was sometimes not wide enough.
- Sometimes long edges were hard to select until both vertices were visible.
- The logger did not detect errors while loading the workbench.
- An edge, or condline was selectable through a surface, even if it was hidden behind that surface.
- Ytruder generated triangles when it should generate quads.
- "Save As..." created a wrong part type (Flexible_Section).
- Divide by zero during Catmull-Clark subdivision
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
