2017-12-20, 21:54
I am reading this page:
http://www.leocad.org/docs/library.html
I am trying to use a few unofficial parts I created alongside the default library. Is it sufficient to just insert the custom parts into "ldrawunf.zip"?
Or is it necessary to do this:
If so, which "parts.lst" file is it talking about? I see no such file in "C:\Program Files (x86)\LeoCAD" or inside "ldrawunf.zip". Thanks.
[edit]
How do I get in touch with the program's author?
Quote:If you are using your own custom library with loose files then all you need to do is make sure you update or delete parts.lst and the parts should be visible next time you start LeoCAD.
[edit]
