Topic for the Modular Buildings theme.
Current Modulars List:
10182 Café Corner (2007) (
On OMR)
10185 Green Grocer (2008) (
On OMR)
10190 Market Street (2007) (
On OMR)
10197 Fire Brigade (2009) (
On OMR)
10211 Grand Emporium (2010) (Posted below)
10218 Pet Shop (2011) (
On OMR)
10224 Town Hall (2012) (
On OMR)
10230 Mini Modulars (2012) (
On OMR)
10232 Palace Cinema (2013) (Posted below)
10243 Parisian Restaurant (2014) (
On OMR)
10246 Detective's Office (2015) (
On OMR)
10251 Brick Bank (2016) (
On OMR)
10255 Assembly Square (2017) (Posted below)
10260 Downtown Diner (2018) (Posted below)
10264 Corner Garage (2019) (
On OMR)
10270 Bookshop (2020) (
On OMR)
10278 Police Station (2021) (Posted below)
10297 Boutique Hotel (2022) (Posted below)
10312 Jazz Club (2023) (TBD)
Wow! Congratulations, Willy!
(2017-12-18, 16:10)Philippe Hurbain Wrote: [ -> ]Wow! Congratulations, Willy!
Thanks, this was kind of a long term project as a few parts had to be made, mainly torsi.
(2017-12-18, 15:37)Willy Tschager Wrote: [ -> ]Topic for the Modular Buildings theme.
10264 Corner Garage.
attachment=3533]
Download MPD (OMR compliant): [
attachment=3532]
Known errors:
- 45 degree angle building technique not 100% accurate (but very close)
- Missing part:6254176 Bunny, No. 5, White (49584)
- Missing some printed parts
- Minifigs not 100% accurate due to missing printed torso's and heads. Used closest parts to compensate.
- Mockup used for: 6217974 Round Plate Ø32X6.4, No. 2 (Parasol)
- Minifig whip used for gashose not formed/shaped
Done with LDCad 1.6b
Rendered with LDView
I just update my post on Creator Expert set 10264 Corner Garage.
It is done and posted here.
(2019-04-09, 20:56)Jaco van der Molen Wrote: [ -> ]- Missing part:6254176 Bunny, No. 5, White (49584)
An impressive list of parts you have to author. I've been working on the
parts for
10246 - Detective's Office for quite a while and have still a few torsi to do.
(2019-04-15, 15:28)Willy Tschager Wrote: [ -> ]An impressive list of parts you have to author. I've been working on the parts for 10246 - Detective's Office for quite a while and have still a few torsi to do.
Most are already on the tracker:
http://www.ldraw.org/cgi-bin/ptscan.cgi?q=10264
Including the dish (parasol) I mocked up
Furthermore I just realized I have used a few unofficial files too.
Will that be a problem?
If not, I can replace all missing parts that are on the tracker in my model.
(2019-04-16, 12:09)Jaco van der Molen Wrote: [ -> ]Most are already on the tracker: http://www.ldraw.org/cgi-bin/ptscan.cgi?q=10264
Hi Jaco
Import please the unofficial files to to the mpd.
File is also not OMR compliant.
Regards Johann
(2019-04-24, 19:41)Johann Eisner Wrote: [ -> ]Hi Jaco
Regards Johann
Ah, OK. I'll do that. Won't be soon though, I think in a week or so.
So beautiful!
Quote:This set required a few parts to be authored
Congratulations for that! I considered virtual build of this set, but gave in considering the number of patterns...
May I suggest to add steps in main models to allow easy browsing of the various floors?
And a part issue: this model requires 92280s01 and stud4g7 (in 92438), but these files are neither in PT or official parts, nor in model embedded files.
(2019-09-22, 15:09)Philippe Hurbain Wrote: [ -> ]And a part issue: this model requires 92280s01 and stud4g7 (in 92438), ...
I don't understad this question. Nothing seams to be missing in my copy...
(2019-09-22, 18:12)Magnus Forsberg Wrote: [ -> ]I don't understad this question. Nothing seams to be missing in my copy...
Indeed, my bad. I opened the file directly from my temp folder that contained old and weird copies of 92280 and 92438.
(2019-04-25, 6:20)Jaco van der Molen Wrote: [ -> ]Ah, OK. I'll do that. Won't be soon though, I think in a week or so.
Hi Jaco
I OMRized the file for you and uploaded it to the OMR.
Johann
Hi there,
I tried to build the 10218 pet shop, which still has some problems. At this point I'd like to share and ask for commenting.
Known problems:
- Not all colors are correct.
- Windows are not all modeled the same way (some frame+glass, other complete; which is better?).
- Center part of MiniFigs are built upon torso+arms+hands instead of pre-built parts.
Edit: please use the updated version below (image didn't change too much, so not replaced).
Thank you so much for all feedback, best regards
Stefan
Very nice!
Quote:- Windows are not all modeled the same way (some frame+glass, other complete; which is better?).
Does not really matter!
Quote:- Center part of MiniFigs are built upon torso+arms+hands instead of pre-built parts.
Since LDraw library has few complete torso shortcuts, this is the expected way.
Quote:- Not all colors are correct.
Not sure to understand. All colors should be available in LDraw?
BTW, do you know you can download part inventories for Rebrickable as a LDCad part bin file (.pbg)? This way you should get the right colors... (provided Rebrickable inventories are OK, sometimes errors may happen!)
(2019-11-04, 16:53)Philippe Hurbain Wrote: [ -> ]Very nice!
Hi Philippe,
thank you very much for the nice words.
I will try to fix the windows so that they are at least "the same way". The colors in LDraw / LDCad are fine, but sometimes I selected the wrong one - until I recognized the existance of the Rebrickable-pbg-file-export...
Apropos Rebrickable-pbg-export: what to do if there are some parts used which in the current LDraw is marked as "moved to..." or just not existing (like in set 854 where 16-technic-brick which is provided as "x.dat" instead of "3703.dat" or "3665.dat" is provided which is "~Moved to 3665a.dat")? I'm just new to official builds, sorry if I missed the answer for this question elsewhere.
Edit: to clarify my question: is it recommended to conform to the Rebrickable database or does it not matter at all? Secondly, in the OMR-tutorial I found "replace ~Moved" by its replacement - is it therefore recommended that I check my OMR-proposals after updating LDraw for maybe-changed "~Moved" parts?
Thanks again and best regards
Stefan
(2019-11-04, 17:13)Stefan Frenz Wrote: [ -> ]Edit: to clarify my question: is it recommended to conform to the Rebrickable database or does it not matter at all? Secondly, in the OMR-tutorial I found "replace ~Moved" by its replacement - is it therefore recommended that I check my OMR-proposals after updating LDraw for maybe-changed "~Moved" parts?
Stefan
Hi Stefan
[color=unset]When you have finished the model, you can use
MPDCenter to check the model for OMR compliance.
This program can also replace the "~moved to" parts and import maybe unofficial parts to the model,
but you can also clean up the model with LDCad's "Cleanup .." before. --->
https://forums.ldraw.org/thread-23733-po...l#pid34457[/color]
[color=unset]Regards
Johann[/color]
(2019-11-04, 20:23)Johann Eisner Wrote: [ -> ]Hi Stefan
[color=unset]When you have finished the model, you can use MPDCenter to check the model for OMR compliance.
but you can also clean up the model with LDCad's "Cleanup .." before. ---> https://forums.ldraw.org/thread-23733-po...l#pid34457[/color]
Johann[/color]
Hi Johann,
thank you for your feedback. I'll use LDCad's cleanup function as suggested by Philippe. Unfortunately, MPDCenter is not working on my XUbuntu machine (tried wine, mono and wine-mono without luck). Therefore I wrote a small Java program to display the difference in used parts between (Rebrickable's) pbg and (my) mpd to clean up the Pet Shop. With your suggestion, I will add a "~Moved"-detection now
and upload the furthermore cleaned file.
Best regards
Stefan
(2019-11-04, 22:04)Stefan Frenz Wrote: [ -> ]Hi Johann,
thank you for your feedback. I'll use LDCad's cleanup function as suggested by Philippe. Unfortunately, MPDCenter is not working on my XUbuntu machine (tried wine, mono and wine-mono without luck). Therefore I wrote a small Java program to display the difference in used parts between (Rebrickable's) pbg and (my) mpd to clean up the Pet Shop. With your suggestion, I will add a "~Moved"-detection now and upload the furthermore cleaned file.
Best regards
Stefan
Hi Stefan[color=unset]
If you clean up the file with LDCad, normally all "~ moved to" parts will be replaced.
Regards Johann[/color]
Thank you Philippe and Johann for your feedback and especially your help with LDCad-options. I hope that parts/colors are correct now and that the file is OMR compliant.
There are two parts 1x1 Plate Round in Dark Bluish Gray more than listed at Rebrickable, but so far I couldn't find the ones that are wrong.
Edit: please use updated version below.
Is there anyone working on 10232, 10255 or 10260?
(2019-11-05, 13:52)Stefan Frenz Wrote: [ -> ]There are two parts 1x1 Plate Round in Dark Bluish Gray more than listed at Rebrickable, but so far I couldn't find the ones that are wrong.
Attached is an updated version which have all parts in the correct color and correct amount.
Done with LDCad 1.6c (Linux64).
File should be OMR compliant.
Known issues: none.
I've added a summary to the top level post.
attachment=5136]
Not OMR Compliant
Missing: 2 patterns (one torso, one slope)
Notes: I have the 2 missing patterns on order. I'll update this model for OMR compliance after I author the missing patterns.
(2020-04-24, 21:23)Orion Pobursky Wrote: [ -> ]Missing: 2 patterns (one torso, one slope)
I'm afraid it's also missing cape cloth at step 15...
(2020-04-25, 7:09)Philippe Hurbain Wrote: [ -> ]I'm afraid it's also missing cape cloth at step 15...
Yah that too. That'll prolly never go in unless I get super bored.
In progress (missing minifigs, paterns and roof windows)
attachment=5155]
(2020-04-29, 18:11)Marc Giraudet Wrote: [ -> ]10224 Town Hall (2012)
Damn, I was already halfway though myself. I'll let you finish.
I'm starting work on the Palace Cinema. I have the sticker sheet on order to create them when it arrives.
I also just got most of the missing torsos (the bride is pricy and not many local BL stores have it) so I'll prolly spend an evening or 2 in the near future making them.
10224 Town Hall
attachment=5158]
attachment=5157]
File OMR compliant.
Known issues :
Part missing : 10830 magnifying glass (unofficial, not included), 93562 and 87990 hairs (Ponytail on the press woman are not the right one)
Paterned part : Torso for bride, press woman, the 2 kids and secretary. 61287 x2 (earth globe).
And 3846 shield (work in progress for this last one).
(2020-04-29, 18:38)Orion Pobursky Wrote: [ -> ]Damn, I was already halfway though myself. I'll let you finish.
Sorry
. I hope my work is as so accurate than yours.
If you work on the 10232 Palace cinema, I propose to make the 10260 Downtown diner (6 Weeks contained, I WANT FRIES !)
(2020-04-30, 10:43)Marc Giraudet Wrote: [ -> ]Sorry . I hope my work is as so accurate than yours.
You can have both Assembly Square and Downtown Diner. I've order most of the missing patterns so I'll have plenty to do on that front.
P.S. I feel your pain. I can't remember that last time I had fast food or, for that matter, food I didn't either prepare myself or get at work. Plus, I really want to go hiking but all the parks and outdoor areas are closed because bozos don't know how to social distance.
(2020-04-30, 10:35)Marc Giraudet Wrote: [ -> ]Part missing : 10830 magnifying glass (unofficial, not included), 93562 and 87990 hairs (Ponytail on the press woman are not the right one)
93562 is on the PT. 87990 hasn't been cleaned up from the LDD data yet
The girl's orange torso (973p96) is on the PT.
Work in progress.
I can't resist, I start with the car. Pink is not my favorite color but this car is really amazing.
attachment=5165]
attachment=5171]
attachment=5170]
Known issues:
Model:
Stair fitting in the wall (rear) is not perfect.
Rendering issue with plant 24855 in studio 2.0
Part missing: 13785 hairs, 98381 hat
Patterned parts missing: 60616 patterned door
5 minifig head pattern
4 minifig torso
1 minifig torso exchange (cook 2 faces printed > 1 face printed 973p8t)
Unofficial parts not included:
92582 x 2 hinge plate (not visible)
973p9w minifig torso
87990 Ponytail
Unofficial parts exchange:
11062 unofficial (lamppost) > 2039
14769p0f unofficial (clock) > 4150p03
(2020-05-03, 11:18)Willy Tschager Wrote: [ -> ]So what was the reason to not use:
https://www.ldraw.org/cgi-bin/ptdetail.cgi?s=11062
I'm stupid, I don't know how include properly an unofficial part (with sub part) in a model with LDCAD.
In that case, the file is not OMR compliant ?
(2020-05-03, 14:30)Marc Giraudet Wrote: [ -> ]I don't know how include properly an unofficial part (with sub part) in a model with LDCAD.
At Prefs / LDraw / Search (library) paths you can add the
unofficial zip file, after this you can just add this part and clean up the file, then everything should be ok.
10211 - Palace Cinema
attachment=5195]
Not OMR Compliant (and can't be with TEXMAP parts until we ratify and implement the !DATA )
Missing:
3 patterns (torsos)
4 Stickers
part 98139, Minifig Weapon Sai
Notes: I'll have 4 missing stickers done as soon as I match fonts to my liking. I have the 3 missing torsos which I'll do eventually or if someone else wants to then I can give them a scan.
(2020-05-07, 19:17)Orion Pobursky Wrote: [ -> ]Notes: I'll have 4 missing stickers done as soon as I match fonts to my liking.
Impact font seems to be close to these missing stickers.
SHOWING
THREE CLICKS
STARRiNG
MINNIE
