2017-12-01, 12:53
just a little bug-fix for Willy's 3D rotation problems under Linux Mint and the wireframe render mode issues with CSG optimisations.
Changelog:
(2 bug fixes)
With this release the following critical issues were fixed:
However, it is still a beta version and something can go wrong in about 120.000 lines of code.
System Requirements:
Minimum System Requirements:
Changelog:
(2 bug fixes)
- The CSG mesh optimisation was deactivated when one of the 3D view had the wireframe render mode enabled.
- Under linux mint it was not possible to rotate/translate the 3D view with the keyboard key (default keys: "M"/"L").
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
