2017-11-30, 11:15
Hey,
this release package includes a lot of new features and bug fixes.
LDPE is now more than five years old!
There are still big goals on my roadmap (LDPatternCreator compatibility, custom plugins, Vulkan support, virtual/augmented reality...).
And I just can't stop to implement new features/enhancements, too ;)
Changelog:
(12 new features and 9 bug fixes)
What will the next release 0.8.39 deliver? You will get more text-editor features and it will fix edge selection issues.
However, it is still a beta version and something can go wrong in about 120.000 lines of code.
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a brand new CSG engine (with automatic mesh optimisation, its on by default)
- ...remove the "UPDATE" info from the part type line with a quick fix.
- ...add the "Unofficial_" prefix to the part type line with a quick fix.
- ...use Isecalc on the current selection by default.
- ...benefit from the fact that "Move Adjacent Data" gets restored on start.
- ...use the new part type "Part Flexible_Section".
- ...see a pop-up dialog with progress bar + cancel for "Calculate Line Intersection Points".
- ...use a "Coplanarity Heatmap Mode" to visually identify coplanar quads.
- ...see some info that the CSG optimisation will only work if the file is displayed on the 3D editor.
- ...turn the new CSG mesh optimisation off (with the meta command 0 !LPE CSG_DONT_OPTIMISE)
- ...set the optimisation threshold of the CSG edge collabser (with the meta command 0 !LPE CSG_EDGE_COLLAPSE_EPSILON 0.9999. The default value is 0.9999. Please use higher or unlikely lower values greater zero and lower one only if necessary.)
- ...set the optimisation threshold of the CSG T-junction finder (with the meta command 0 !LPE CSG_TJUNCTION_EPSILON 0.1. The default value is 0.1 LDU. Please use lower or unlikely higher values greater zero only if necessary.)
- MeshReducer did a wrong check for common points.
- The label for hints, warnings, etc. was cut off.
- TJunctionFinder was not able to fix T-junctions automatically.
- When you double-clicked on the last word in the last line, the last character of the file was not selected.
- The visible line size for CSG selections was not always correct.
- Subdivision silently removed all condlines (now it warns about this!)
- The quick fix for missing part type didn't remove the truncated "0 !LDRAW_ORG" meta command.
- "Radio buttons" were not highlighted on the grid icons and in the Ytruder tool dialog.
- Rare NullPointerException during a double click on the text editor problem tree.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
