Hi all,
I would like to use the 322 color (medium azure).
According to
here, it should be available, but it is an "unused" color in MLCAD and it shows as brownish in ldview.
What am I doing wrong?
Thanks for the help.
(2017-09-16, 17:21)Damien Roux Wrote: [ -> ]Hi all,
According to here, it should be available, but it is an "unused" color in MLCAD and it shows as brownish in ldview.
You'll probably using an old library as 322 is indeed defined in LDConfig.ldr of the current comlete.zip.
(2017-09-16, 17:29)Roland Melkert Wrote: [ -> ]You'll probably using an old library as 322 is indeed defined in LDConfig.ldr of the current comlete.zip.
If I remember well, MLCad must be properly configured to use LDConfig. There are buttons for that in color menu (M in color toolbar)
(2017-09-16, 17:29)Roland Melker Wrote: [ -> ]You'll probably using an old library as 322 is indeed defined in LDConfig.ldr of the current comlete.zip.
Updating LDConfig.ldr did the job. Thanks a lot!
