Will post some of my Star Wars models here.
First one the First Order Special Forces TIE Fighter (75101)
MPD is attached. Minifigs are missing, but contains stickers and patterns
75155 - Rebel U-Wing Fighter
No Minifigs, MPD contains the patterns and stickers.
75102 - Poe's X-Wing Fighter
No minifigs, MPD contains the patterned windscreen and stickers.
75048 - The Phantom
The MPD contains the patterned cockpit window and stickers, no minifigs.
(2017-09-02, 17:43)Evert-Jan Boer Wrote: [ -> ]First one the First Order Special Forces TIE Fighter (75101)
I saw that you also made the patterns for the Dish 18675, will you upload them to the PT? They look great!
75053 - The Ghost
No minifigs, with stickers and patterns.
It's by far not the end of the world, but that file should have the .mpd file extensions instead of .ldr
Nice work on all those patterns/stickers btw.
10240 - Red Five X-Wing Starfighter
Complete, specs sticker done with texmap, this does not show with povray.
Still having some issues with the stickers on the cockpit window, transparant stickers on transparant parts do not show very well in LDView.
MPD:
Link to specs sticker:
6041468j
Quote:Complete, specs sticker done with texmap, this does not show with povray.
I do have the same issue when I export to POV with LDView, but LDCad does export texmap. BTW, I played a bit with photoshop trying to improve specs sticker (attached). [
attachment=2896]
Quote:Still having some issues with the stickers on the cockpit window, transparant stickers on transparant parts do not show very well in LDView.
LDView attenuates background image at each surface it goes through. With the sticker, that's 4 layers (top and bottom layer of sticker, top and bottom layer of cockpit. You can cheat by removing useless surfaces (bottom sticker quad, top cockpit surfaces)
attachment=2898][
attachment=2899]
(2017-09-11, 9:27)Philippe Hurbain Wrote: [ -> ]Quote:Complete, specs sticker done with texmap, this does not show with povray.
Do note that because the textmap is in a submodel that whole submodel will be exported to povray as a single mesh2. If you separate that sticker into its own submodel you can probably do a 'transplantation' to merge it into the LGEO using export of LDView. As LDCad's exports are primarily aimed at animation (so not extreem HQ).
Hi every one.
My son built this model.
The Tie fighter 75211
with the model under Leocad,
took me less than 2 hours to complete.
Wow! But I would prefer that you inline the pictures.
(2021-05-15, 16:31)hehud Wrote: [ -> ]how to embed pictures ?
Press the 2nd icon the 4th tab of the formating toolbox showing a screen with a + in the bottom right-hand corner and add your URL in the popping up dialog.
Are these official models and part of the OMR?
Yes it's the 75252 Imperial Star destroyer,
I done every single pieces, , I just had trouble, cause of the angles, the pieces get
I will send pics of the inside, there is no mistakes to my knowledges, , but some many pages,
the other one is the 75211 tie fighter fully done no mistakes
(2021-05-19, 20:08)hehud Wrote: [ -> ]Yes it's the 75252 Imperial Star destroyer,
If you would still make the file OMR compliant, I could upload it to the OMR.
Documentation: Official Model Repository (OMR) Specification
Venator officiel, full except stikers...
