2017-08-30, 19:09
here is a release which wipes out some critical bugs.
Changelog:
(7 bug fixes)
What will the next release 0.8.38 deliver? A new CSG engine with great triangulation features...
System Requirements:
Minimum System Requirements:
Changelog:
(7 bug fixes)
- Edger2 created duplicated TYPE 2 lines which were hard to spot.
- The primitive text search field was sometimes failing / sometimes primitives were not shown at all.
- Edger2 only created condlines if the adjacent surfaces vertices matched perfectly.
- Undo/Redo did not work with the CSG_EXTRUDE meta command.
- CSG inlining did not use all CPU cores.
- The new numeric input fields were blocking the common thread pool (no crash, only performance degradation).
- There was an endless loop regarding the new numeric input fields (no crash, only performance degradation).
- Download the zip-Archive
- On linux, you have to excecute the shell script "update.sh".
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
