2017-08-18, 5:39
Hey,
here is a new release. It was intended to be released earlier, but now it has more value for you
Changelog:
(11 new features and 5 bug fixes)
What will the next release 0.8.37 deliver? Bug fixes...
System Requirements:
Minimum System Requirements:
Changelog:
- ...select (and see in 3D view) elements producing an error or warning (when meaningful).
- ...benefit from improved usability for the "hover over right click menu-icon" in the 3D view.
- ...benefit from the fact that vertices which are close together are considered "as one" (when you add something; dist < threshold in LDU).
- ...customise the 3D distance below which vertices are considered the same when you add new elements.
- ...customise the 2D distance in pixels below which vertices are considered the same when you add new elements.
- ...see a warning if the value of a DecimalSpinner differs from the displayed value.
- ...drag&drop primitives on the text editor.
- ..."Select Connected..." / "Touching..." "...with same type."
- ...notice that closing a tab in the text editor close it also in the 3D editor, when the 3D and text editors share one window.
- ...select objects, regardless of the selection filter (but there are some special exceptions).
- ...benefit from more eye-catching buttons.
- Rectifier: There was no difference in the result on the fourth filter. "Convert if possible/Do not convert if adjacent cond-line."
- Text-Editor: The cursor jumped to the first line when the file was saved / the Save-button "stayed" in 'down'-position (actually, it was focused).
- The 3D editor placed the tab of a newly opened part on the left of an already opened part, while in the text editor it was placed as expected on the right.
- Selection issues with vertices which were close together on the screen.
- The coplanarity calculation was incomplete.
- Download the zip-Archive
- On linux, you have to excecute the shell script "update.sh".
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
