2017-08-17, 3:31
I'm having a problem when rendering part 32293 (Technic Steering Link 1x9) from LPub3D in POV-Ray with LGEO enabled. When using LGEO, the part is shifted downward 2 LDUs, causing an overlap with the towball pins at either end.
[attachment=2873]
When I disable LGEO, the part is rendered correctly:
[attachment=2874]
It is also rendered correctly when using LDGLite:
[attachment=2875]
I see the same problem with I use LDView to export the model to a .pov file and render it directly.
As far as I can tell, I don't have an LGEO substitute for part 32293.
Any ideas what is happening and what I can do to fix it?
Thank you.
Kevin
[attachment=2873]
[attachment=2874]
[attachment=2875]
Thank you.
Kevin
