2017-08-05, 19:53
Hey,
a new release with dozens of fresh features and three bug fixes for Windows, Linux and Mac
Changelog:
(11 new features and 3 bug fixes)
System Requirements:
Minimum System Requirements:
Changelog:
- ...benefit from better decimal spinner widgets.
- ...make use of a "Select All Types" and a "Select Nothing" menu item along with Vertices, Lines, Triangles, etc.
- ...use "Show All" in the context menu from the text editor
- ...use a shortkey to swap the BFC winding of a selection ("J" key).
- ...see where the distance meter starts.
- ...see where the protractor is fixed.
- ...use the selection filter to control the element types which are inserted by copy & paste
- ...use the selection filter to control which element types are selectable.
- ...see tooltips which explain that ALT+Click removes the corresponding object type from selection when you activate Vertex/Surface/Line/Subfile Mode
- ...benefit from better performance if you have a large number of hidden objects.
- ...benefit from the fact that the primitive area is reset to the top left corner on load.
- Selection got cleared while using the subfile mode.
- Wrong number format for the "Stud" in the unit converter.
- Snap on edges: The projection was incorrect.
- Download the zip-Archive
- On linux, you have to excecute the shell script "update.sh".
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
