2017-07-20, 19:30
Hey,
here are eight new features and one bug fix with a new version of LDPE for Windows, Linux and Mac
Changelog:
(8 new features and 1 bug fix)
System Requirements:
Minimum System Requirements:
Changelog:
- ...see some information for the number of currently selected parts in the status bar.
- ...copy protractor and distance meter values in the clipboard.
- ...hide/unhide things from the text editor.
- ...see (in text editor) which lines are currently hidden (you can customise the colour in the options menu).
- ...use the shortkey "B" to toggle "Move Adjacent Data" (you can customise the key in the options menu).
- ...control if the mesh reducer tool should not destroy patterns.
- ..."Draw Only the Selection" (text editor context menu)
- ..."Draw Until Selection" (text editor context menu)
- The undo/redo feature for hidden and shown elements was not correct.
- Download the zip-Archive
- On linux, you have to excecute the shell script "update.sh".
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
