Full Version: Looking for ooold part references...
I had a look at this oddball model: http://www.eurobricks.com/forum/index.ph...nt=2825330 and noticed that the author uses parts that have disappeared from parts tracker, namely x913 and x914.
Using this query http://www.ldraw.org/cgi-bin/tracker/act...s/x914.dat I see that x914 was renamed as parts/3142s04.dat, but this reference is not available either... and this query http://www.ldraw.org/cgi-bin/tracker/act...142s04.dat doesn't show any delete or file name change, but parts/3142s04.dat is no longer on PT...
Finally, Peeron links x913/x914 to parts 31057/31050 but these are... Duplo dinosaurs !!!????
Any hint???
(2017-07-13, 9:33)Philippe Hurbain Wrote: [ -> ]Any hint???
Yes, using the Wayback Machine I found it.
It looks like all you need to do is to drop the x. x913.dat is 913.dat and x914.dat is 914.dat.
A lever and axle in 32288c01.dat and 32288c02.dat.
Thanks, Magnus. Shame on me, I should have thought of looking at 913/914! What fooled me was the rename as 3142s03 / 3142s04... because I looked at the history in the wrong direction Wink It was a rename from 3142s04 to x914, not the contrary!!!
