Hey,
here is a new release with one new feature and four bug fixes.
Download and install the latest LDPatternCreator release directly from
sourceforge.net.
Change log:
New features:
- The program restores now the visibility of the grid and the colour bar on start.
Fixed bugs:
- Crashes on export (thanks to Philo for testing!)
- *.dat-Export: the proposed file name contained a full path to the LDPatternCreator executable.
- The projection data import modified the pattern metadata.
- The calculation for round primitives (circle / oval) was incorrect
As always, I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
Bug of the day:
* When you ungroup a colored primitive (4-4disc for example) the triangles are converted to main color 16.
* I also had a crash but cannot find the log file anymore. Where are the .net log files supposed to be stored?
(2017-07-15, 22:04)Willy Tschager Wrote: [ -> ]Bug of the day:
Hi Willy,
to my regret, LDPatternCreator does not create a helpful logfile, yet.
Leg godt
Nils
Nils,
this file:
attachment=2908]
crashes LDPC. I WOULD LOVE IF YOU COULD RESCUE THE FILE AS I HAVE INVESTED CONSIDERABLE WORK INTO IT!
Before the I added a help line and got this pop-up:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.ArgumentOutOfRangeException: Der Index lag außerhalb des Bereichs. Er darf nicht negativ und kleiner als die Sammlung sein.
Parametername: index
bei System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
bei System.Collections.Generic.List`1.get_Item(Int32 index)
bei LDPatternCreator.MainForm.MainForm_Paint(Object sender, PaintEventArgs e)
bei System.Windows.Forms.Control.OnPaint(PaintEventArgs e)
bei System.Windows.Forms.Form.OnPaint(PaintEventArgs e)
bei System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
bei System.Windows.Forms.Control.WmPaint(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ScrollableControl.WndProc(Message& m)
bei System.Windows.Forms.Form.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 4.0.0.0.
Win32-Version: 4.7.2102.0 built by: NET47REL1LAST.
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll.
LDPatternCreator
Assembly-Version: 1.6.6.0.
Win32-Version: 1.6.6.0.
CodeBase: file:///C:/Program%20Files%20(x86)/LDraw%20Author%20Tools/LDPatternCreator/LDPatternCreator.exe.
Microsoft.VisualBasic
Assembly-Version: 10.0.0.0.
Win32-Version: 14.7.2046.0 built by: NET47REL1.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll.
System
Win32-Version: 4.7.2103.2 built by: NET47REL1LAST.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
Win32-Version: 4.7.2104.0 built by: NET47REL1LAST.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System.Drawing
Win32-Version: 4.7.2046.0 built by: NET47REL1.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll.
System.Deployment
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll.
System.Deployment.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment.resources/v4.0_4.0.0.0_de_b03f5f7f11d50a3a/System.Deployment.resources.dll.
System.Windows.Forms.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
mscorlib.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
I addition LDPC got very slow while I added more and more triangles.
