2017-06-24, 20:09
here are seven new features and the first official LDPE release on Mac OS X :)
Changelog:
(7 new features and 4 bug fixes)
System Requirements:
Minimum System Requirements:
Changelog:
- ...use LDPartEditor under Mac OS X.
- ...move the 3D view with Alt+Cursor Keys
- ...enable a verbose mode for Rectifier
- ...enable a verbose mode for Edger2
- ...specify the number of iterations for the "Rotate Dialog"
- ...specify the number of iterations for the "Translate Dialog"
- ...copy and transform a selection if you hold Ctrl and modify the manipulator with the cursor keys
- ...benefit from an absolute scaling mode which uses a length in LDU as an initial scale.
- Ctrl+Z with focus on 3D window shifted the focus to the text window.
- A mouse click was sometimes ignored (while adding something in the 3D view)
- Unificator: A vertex already snapped on a primitive vertex was able to move to another primitive.
- Minor bug: The primitive area renderer tried to render after the 3D window was closed.
- Download the zip-Archive
- On linux, you have to excecute the shell script "update.sh".
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
