2017-06-17, 23:29
Hey,
in the last weeks I had much fun at work and some time on the weekend for LDPE :)
Changelog:
(10 new features and 6 bug fixes)
System Requirements:
Minimum System Requirements:
Changelog:
- ...see the distance traveled/angle rotated in the status bar while using the move or rotate tool.
- ...access the manipulator features from a sub menu in the 3D editor context menu.
- ...see a tooltip for view rotation in the primitive area.
- ...move the Manipulator with left/right or up/down arrows on keyboard.
- ...remove all "0 // Inlined:" notices with a "quick fix".
- ...download/update the "ldconfig.ldr" file from LDraw.org.
- ...download/update the "categories.txt" file from LDraw.org.
- ...benefit from much faster undo/redo.
- ...benefit fom a faster program start.
- ...benefit from the fact that when using the translate/scale/set etc actions, it displays the global axis, if global mode is active.
- Sometimes, deselected elements were re-selected when selecting a subpart.
- "Save As..." did not trigger a check for warnings / hints / errors
- "LDConfig.ldr" / "ldconfig.ldr" issues on case sensitive file systems.
- LDPE false reported that the single !HELP meta command was "split apart".
- Sometimes, the UI freezed permanently under Linux.
- Implementation: Little resource leak with org.eclipse.swt.graphics.Cursor instances.
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
