Hi all,
Is this made?
https://brickset.com/parts/design-14181
Its been around since 2010, but I can only find an "old" version of this "Wing 4 x 9" without stud notches, part 2413.
Or does it have, like many parts, an alternative part number?
(2017-06-07, 19:28)Magnus Forsberg Wrote: [ -> ] (2017-06-07, 18:06)Philippe Hurbain Wrote: [ -> ]Working on it...
Have you seen this article at New Elementary?
Forgot about it... Thanks, it confirms that LDD model is wrong (it misses the rounded tip corners)
(2017-06-08, 6:52)Philippe Hurbain Wrote: [ -> ] (2017-06-07, 19:28)Magnus Forsberg Wrote: [ -> ]Have you seen this article at New Elementary?
Your rounded corners appear to be misaligned:
Furthermore, where you have a protrusion from the top edge to make the stud hole on the right, the pictures on New Elementary imply the opposite (a thinning of the top edge). I don't have the part in hand to see what it really looks like, although I suspect that I do own it.
Thanks, I'll have a closer look!
(2017-06-08, 19:02)Philippe Hurbain Wrote: [ -> ]Done... http://www.ldraw.org/cgi-bin/ptdetail.cg.../14181.dat
Always amazed that a useful part like this was not requested before!
Thanks Philo.
Amazing indeed since this notched version of this wing has been there since 2010!
I absolutely need this version since the none-notched version does not fit in my model :-)
(2017-06-08, 19:33)Travis Cobbs Wrote: [ -> ]Furthermore, where you have a protrusion from the top edge to make the stud hole on the right, the pictures on New Elementary imply the opposite (a thinning of the top edge). I don't have the part in hand to see what it really looks like, although I suspect that I do own it.
Corrected the rounded corner, but I let the notch as in LDD model since a stud fits properly the notch, and I didn't know the exact shape anyway.
