The propellor blades are available as official LDraw parts since 2011 second update, if you don't find it maybe you need to reinstall your LDraw parts. The other parts are missing. I do have them, but they need a lot of work...
(2017-05-09, 17:31)Philippe Hurbain Wrote: [ -> ]The propellor blades are available as official LDraw parts since 2011 second update, if you don't find it maybe you need to reinstall your LDraw parts. The other parts are missing. I do have them, but they need a lot of work...
Really? I have re installed but I haven't found the propeller yet. Could you tell me where to download this part?
(2017-05-10, 5:59)yongxu wang Wrote: [ -> ]Really? I have re installed but I haven't found the propeller yet. Could you tell me where to download this part?
Are you sure that you have only one library on your machine? maybe you updated a library but your editor uses another?
Otherwise, the part is avalable here
http://www.ldraw.org/library/official/parts/89509.dat but you should not need to download a single official part if your library was healthy and properly configured.
(2017-05-10, 6:49)Philippe Hurbain Wrote: [ -> ] (2017-05-10, 5:59)yongxu wang Wrote: [ -> ]Really? I have re installed but I haven't found the propeller yet. Could you tell me where to download this part?
Otherwise, the part is avalable here http://www.ldraw.org/library/official/parts/89509.dat but you should not need to download a single official part if your library was healthy and properly configured.
Thank u, and one more question. I reinstall LDraw today. But why does mlcad always remind me to lose a lot of parts?
(2017-05-10, 13:40)yongxu wang Wrote: [ -> ] (2017-05-10, 6:49)Philippe Hurbain Wrote: [ -> ]Are you sure that you have only one library on your machine? maybe you updated a library but your editor uses another?
I have solved the above problem thank you.
(2017-05-10, 14:29)yongxu wang Wrote: [ -> ]I have solved the above problem thank you.
Great
If you don't have yet a long experience with MLCad... you should try a much more modern and powerful editor:
LDCad
