Full Version: [LDPartEditor] 0.8.31 Beta Released (!LPE VERTEX / Usability / bugfix)
Hello,
I fixed ten issues within the last week, so... here is a new release Smile
[Image: imgDuke2.png]
Changelog:
(6 new features and 4 bug fixes)
  • ...delete a !LPE VERTEX without "Move Adjacent Data" being on.
  • ...see the selection of !LPE VERTEX meta commands (3D -> text).
  • ..."Show Selection In 3D View" of a !LPE VERTEX line in text editor.
  • ..."Show Selection In Text Editor" of a !LPE VERTEX line in 3D view.
  • ...add a !HISTORY line quickly in the text editor (with Ctrl+H).
  • ...add a !KEYWORDS line quickly in the text editor (with Ctrl+K).
  1. YTruder accidentally deleted the selected lines.
  2. YTruder was not able to do symmetry or projection on planes with value=0
  3. Toggle comment / !TEXMAP freezed the text editor on empty lines.
  4. SyncEdit did not mark the !LPE VERTEX meta command.
What will the next release 0.8.32 deliver? Bug fixes, more header validation features, usability improvements...
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
Thanks  Smile
When using the translate/scale/set etc actions, an axis thingy is displayed to show origin and orientation, which is a Good Thing. But the displayed thingy is always the local one, even if we are in global mode. And there it becomes misleading!
Otherwise, I see that I mistakenly put may last two posts in 0.8.28 thread instead of this one... and I didn't find how to move them.
Another conveniency one...
As a user, I'd like to be able to remove all "0 // Inlined:" notices with a "quick fix".
As a user I want to move the Manipulator with left/right or up/down arrows on my keyboard.
Something like this:
  • select something, a vertex/line/surface/prim.
  • set Manipulator position
  • set move/rotate/scale step/distance/angle
  • "mouse over" one of the axis on the Manipulator
  • move one step by pressing left/right or up/down arrow key once
Select by mouse click and drag'n'drop is difficult when I only want to finetune something.
This, select and move something, is possible in LDPC. Why not in LDPE?
I'd appreciate keyboard movements too...
Looks like LDPE embedded Edger2 sometimes creates erroneous edge lines in flat areas... Attached the original file, result with command line Edger2, result with LDPE Edger2. Problem occurs near the tread rounded tips of tread. Default parameters, no generation of unmatched lines.
Found the culprit: overlapping surfaces. I was fooled because minute rounding errors made these overlaps unnoticed by LDPE duplicate detection engine.
When I double-click "run.bat", the document flashes back. What's the matter?
(2017-05-24, 2:38)yongxu wang Wrote: [ -> ]When I double-click "run.bat", the document flashes back. What's the matter
It has been solved。Now learn how to use it
(2017-05-24, 4:36)yongxu wang Wrote: [ -> ]
Good luck Wink What was the problem? Incorrect installation of JRE?
(2017-05-24, 15:17)Philippe Hurbain Wrote: [ -> ]
(2017-05-24, 4:36)yongxu wang Wrote: [ -> ]It has been solved。Now learn how to use it
The JDK version is not high enough. Do you have any other tutorials published on other websites? YouTube can't land in china.
Is there a way to deform a rotated edge-prim around a cylinder?
I want to deform this:
1 16 0 3 0 -2.296101 0 -5.543277 0 1 0 5.543277 0 -2.296101 3-8edge.dat
to replace this:
1 16 0 3 0 -6 0 0 -6 1 0 0 0 -6 3-16edge.dat
1 16 0 3 0 -6 0 0 -6 1 0 0 0 6 3-16edge.dat
Or, How do I rotate a sloping edge around a sloping surface through a cylinder?
For cylinders oriented in Cartesian directions you can rely on slicerpro or projector. But Ldpe is definitely missing a slant tool !
Otherwise I think the two prims version is not bad...
I would like to announce, that the next version of LDPE will start faster (it takes five seconds now on my machine).
(2017-06-12, 20:55)Nils Schmidt Wrote: [ -> ]I would like to announce, that the next version of LDPE will start faster (it takes five seconds now on my machine).
Yeah!!! [Image: heart.png]
The next version will have faster undo/redo actions without the annoying progress bar popups.
(2017-06-15, 11:58)Nils Schmidt Wrote: [ -> ]The next version will have faster undo/redo actions without the annoying progress bar popups.
Well... progress bar was good to know that something was happening. Of course if the new undo/redo is extremely fast progress bar becomes useless Wink
(2017-06-15, 14:02)Philippe Hurbain Wrote: [ -> ]Well... progress bar was good to know that something was happening. Of course if the new undo/redo is extremely fast progress bar becomes useless Wink
Undo/redo is now as fast as a manual action. Take a look at this simple example:
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 arm1.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 arm2.dat
1 4 0 0 0 -1 0 0 0 1 0 0 0 -1 arm1.dat
If I change the colour of arm1.dat to 4 and I trigger an undo afterwards, the old implementation will parse the whole file (BFC, arm1.dat and arm2.dat).
The new implementaion will only parse this line:
This example file has only three lines, but the performance gain is huge for files with 1000+ lines.
Fast start up is good, but a faster undo/redo is way more wanted.... Heart
(2017-05-17, 9:10)Philippe Hurbain Wrote: [ -> ]When using the translate/scale/set etc actions [...] the displayed thingy is always the local one, even if we are in global mode. And there it becomes misleading!
I solved this issue now (#544).
(2017-05-17, 11:36)Philippe Hurbain Wrote: [ -> ]As a user, I'd like to be able to remove all "0 // Inlined:" notices with a "quick fix".
Done (#545)
(2017-05-17, 18:59)Magnus Forsberg Wrote: [ -> ]As a user I want to move the Manipulator with left/right or up/down arrows on my keyboard.
Done! (#537)
It is possible to do this without fiddling with the mouse, too (as an addition to "mouse over").
You can pre-select an axis with the keyboard and then transform the selection one step on the selected axis with the cursor keys.
  • F6 selects the X axis
  • F7 selects the Y axis
  • F8 selects the Z axis
  • F9 selects the X+Y axis
  • F10 selects the X+Z axis
  • F11 selects the Y+Z axis
  • F12 selects the X+Y+Z axis
ESC cancels the selected axis.
  • UP moves in the direction of the axis arrow (increment)
  • RIGHT moves in the direction of the axis arrow (increment)
  • DOWN moves against the direction of the axis arrow (decrement)
  • LEFT moves against the direction of the axis arrow (decrement)
