2017-04-08, 14:36
Hello,
I fixed ten issues within the last week, so... here is a new release
Changelog:
(6 new features and 4 bug fixes)
System Requirements:
Minimum System Requirements:
Changelog:
- ...delete a !LPE VERTEX without "Move Adjacent Data" being on.
- ...see the selection of !LPE VERTEX meta commands (3D -> text).
- ..."Show Selection In 3D View" of a !LPE VERTEX line in text editor.
- ..."Show Selection In Text Editor" of a !LPE VERTEX line in 3D view.
- ...add a !HISTORY line quickly in the text editor (with Ctrl+H).
- ...add a !KEYWORDS line quickly in the text editor (with Ctrl+K).
- YTruder accidentally deleted the selected lines.
- YTruder was not able to do symmetry or projection on planes with value=0
- Toggle comment / !TEXMAP freezed the text editor on empty lines.
- SyncEdit did not mark the !LPE VERTEX meta command.
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
