Full Version: [LDPartEditor] 0.8.30 Beta Released (YTruder)
Pages: 1 2
again, a new month starts with a new version (no April fool)!
[Image: imgDuke2.png]
Changelog:
(4 new features and 6 bug fixes)
  • ...use a keyboard shortcut (F) to Flip/Rotate vertices.
  • ...use Ytruder.
  • ...see that the menu bar tools button became a normal sized "Tools..." button (was a tiny arrow).
  • ...see the triples of "protractor" and "distance" as well as the color digit colored.
  1. It was not possible to set the length of the protractor.
  2. "Flip/rotate vertices" transformed protractors into triangles and distance meters into lines.
  3. Wrong transparency calculation for transparent PNG textures (!TEXMAP)
  4. One search path was missing (!TEXMAP parser)
  5. Wrong "Circular reference" error on subfiles in combination with !TEXMAP
  6. All axes were enabled if you used the "Translate..." feature (X/Y/Z)
What will the next release 0.8.31 deliver? Bug fixes, more header validation features, usability improvements...
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, LDPE 0.8.30 was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
Thanks, will test when I'm back home Smile
With the release of 0.8.30, a little bug was introduced. SyncEdit does not enframe the coordinates of the !LPE VERTEX meta command anymore.
I'll fix this cosmetic issue with release 0.8.31.
(2017-03-28, 7:36)Philippe Hurbain Wrote: [ -> ]
(2017-03-27, 18:30)Nils Schmidt Wrote: [ -> ]Should I change the behaviour of the deletion (if "Move Adjacent Data" is not activated)?
I think that once it is possible to check selection between text editor and 3Dview, it should be possible to delete a !LPE vertex without "Move Adjacent Data" being on.
Wishes of the day...
- as a user I'd like to be able to "show selection in 3D view" of a !LPE VERTEX line in text editor
- as a user I'd like to be able to "show selection in text editor" of a selected !LPE vertex in 3D view
- as a user I'd like to be able to delete a selected !LPE vertex in 3D view
I implemented all these features now (#522, #526, #527).
As a user I want an easy way to add:  0 BFC INVERTNEXT.
I want to right-click on a primitive in the 3D-viewer and choose: Invert this primitive.
Or, I want to select a line in the text editor and choose: Invert this primitive.
As a user I want an easy way to add a new history statement:    0 !HISTORY ("today date") ["username"]   in the header.
(2017-04-06, 16:20)Magnus Forsberg Wrote: [ -> ]As a user I want an easy way to add:  0 BFC INVERTNEXT.
Maybe I don't understand what you need, but selecting a primitive or a line in text editor and hit the "swap BFC winding" button in either editor does just that.
Quote:As a user I want an easy way to add a new history statement:    0 !HISTORY ("today date") ["username"]   in the header.
+1
...and keywords too !
Quote:...use Ytruder.
Tested a bit...
- I don't think that deleting the lines that were extruded is a good idea, generally the extruded surface has an edge...
- It seems impossible to use symmetry or projection with value=0 while both are meaningful (opposite to translation!)
- Not utterly annoying, but I don't understand why triangles are sometimes generated for translation mode. This should only produce quads?
(2017-04-06, 16:33)Philippe Hurbain Wrote: [ -> ]hit the "swap BFC winding" button
Yes, that's exactly what I wanted.  Why didn't I think of trying that button...
(2017-04-06, 16:20)Magnus Forsberg Wrote: [ -> ]As a user I want an easy way to add a new history statement:    0 !HISTORY ("today date") ["username"]   in the header.
I implemented this feature a few moments ago (#528).
+1
I finished the implementation of this feature a few moments ago (#529).
Pages: 1 2
