2017-04-02, 19:13
again, a new month starts with a new version (no April fool)!
Changelog:
(4 new features and 6 bug fixes)
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a keyboard shortcut (F) to Flip/Rotate vertices.
- ...use Ytruder.
- ...see that the menu bar tools button became a normal sized "Tools..." button (was a tiny arrow).
- ...see the triples of "protractor" and "distance" as well as the color digit colored.
- It was not possible to set the length of the protractor.
- "Flip/rotate vertices" transformed protractors into triangles and distance meters into lines.
- Wrong transparency calculation for transparent PNG textures (!TEXMAP)
- One search path was missing (!TEXMAP parser)
- Wrong "Circular reference" error on subfiles in combination with !TEXMAP
- All axes were enabled if you used the "Translate..." feature (X/Y/Z)
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
