2017-03-01, 9:22
a new month starts with a new version!
Changelog:
(7 new features and 2 bug fixes)
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a tool that creates a vertex on line intersection.
- ...use a "Create Copy" button for the transformation tools (translate / rotate / scale selection / set X,Y,Z)
- ...see the manipulator while using the transformation tools (translate / rotate / scale selection / set X,Y,Z)
- ...set the translation to the manipulator position (translate selection)
- ...use "Set x/y/z" to set the origin of subfiles and primitives to x/y/z
- ...benefit from the fact that colour changes to the main colour are updated after leaving the options menu.
- ...benefit from the fact that the dialog for local rotation and scale transformations now initialises the pivot point with the manipulator position.
- "Moved to" reference resolve function for subfiles, 8- and 48-primitives was incorrect.
- "More Colours..." did not work after the colour palette was reloaded.
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
