2017-02-21, 21:29
2018-10-07, 11:55
2018-10-07, 11:58
2018-10-07, 13:34
I have the feeling that model is floating slightly above ground?
2018-10-07, 14:26
(2018-10-07, 13:34)Philippe Hurbain Wrote: [ -> ]I have the feeling that model is floating slightly above ground?
Mmh, PovRay plane is at Y = 17. The lowest point of the tyre in LDCad is at Y = 17. So it must be something due to the lightning in PovRay.
2018-10-07, 17:44
(2018-10-07, 14:26)Max Martin Richter Wrote: [ -> ]Mmh, PovRay plane is at Y = 17. The lowest point of the tyre in LDCad is at Y = 17. So it must be something due to the lightning in PovRay.Indeed, I think it's a visual effect caused by the alignment of tire treads and shadow.
Out of curiosity, I also rendered the dozer with Studio:
2018-10-10, 19:21
2018-10-10, 19:22
2018-10-10, 19:26
2018-10-10, 19:26
2018-10-13, 11:13
2018-10-13, 11:14
2018-10-27, 11:59
![[Image: 800x600.jpg]](https://bricksafe.com/files/MMR1988/ldraw/8856/8856%20-%20Whirlwind%20Rescue%20-%20Whirlwind%20Rescue.png/800x600.jpg)
[color=#0072bc]Download MPD[/color] (OMR compliant)
Known errors: No Stickers.
Done with LDCad 1.6b ;angle calculation of the front was done with a self written excel tool for solving a four-joint problem with excels "GoalSeek" function.
2018-10-27, 16:42
(2018-10-27, 11:59)Max Martin Richter Wrote: [ -> ]angle calculation of the front was done with a self written excel tool for solving a four-joint problem with excels "GoalSeek" function.Interesting problem... and solution!
2018-10-30, 23:50
2018-12-30, 11:07
![[Image: 800x450.jpg]](https://bricksafe.com/files/MMR1988/ldraw/8074/8074%20-%20Universal%20Set%20with%20Flex%20System%20-%20Tractor.png/800x450.jpg)
Known errors: None.
![[Image: 800x450.jpg]](https://bricksafe.com/files/MMR1988/ldraw/8074/8074%20-%20Universal%20Set%20with%20Flex%20System%20-%20Mini%20Loader.png/800x450.jpg)
Known errors: None.
![[Image: 800x450.jpg]](https://bricksafe.com/files/MMR1988/ldraw/8074/8074%20-%20Universal%20Set%20with%20Flex%20System%20-%20Road%20Grader.png/800x450.jpg)
Known errors: None.
![[Image: 800x450.jpg]](https://bricksafe.com/files/MMR1988/ldraw/8074/8074%20-%20Universal%20Set%20with%20Flex%20System%20-%20Crane.png/800x450.jpg)
Known errors: None.
With this set all main Technic Sets from 1991 are available as OMR-files. Only the "Idea Set" from the initial post needs to ge OMRized. I'll do this soon...
2018-12-31, 13:30
![[Image: 800x450.jpg]](https://bricksafe.com/files/MMR1988/ldraw/120270/120270%20-%20Racer.png/800x450.jpg)
Known errors: None.Done with LDCad 1.6b
Note: I'm not sure about the number as this set comes from 'idea book' which was included in 8815.
Note 2: The 1991 Technic Series is now complete.
2019-01-04, 20:00
(2018-12-31, 13:30)Max Martin Richter Wrote: [ -> ][color=#0072bc]Download MPD[/color] (OMR compliant)Known errors: None.
All sets now on the OMR.
Thanks.
Johann
