Full Version: [LDPartEditor] 0.8.28 Beta Released (local/global transformation, col. 16, merge)
Hey,
after I released a new version of LDPatternCreator (LPC) in the beginning of this month, it is now time for the "bigger brother" LDPE :)
[Image: imgDuke2.png]
Changelog:
(4 new features and 4 bug fixes)
  • ...override colour 16.
  • ...set the distance meter length in the selection window.
  • ...constrain "Merge to Nearest..." to operate in a fixed direction (X/Y/Z).
  • ...choose between world axis X/Y/Z and manipulator axis X/Y/Z for transformation tools (translate / rotate / scale selection / set selection X/Y/Z)
  1. The colour value for colour 16 was not read from LDConfig.ldr
  2. If you split a distance meter you got two normal edge lines instead of two distance meters.
  3. LDPE did not complain about some duplicated lines (TYPE 2, 3, and 4).
  4. "Local" mode for the distance meter showed sometimes wrong values for dx / dy / dz
What will the next release 0.8.29 deliver? Bug fixes, more header validation features, usability improvements...
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, LDPE 0.8.28 was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
Works great so far Wink
One question: shouldn't "set x/y/z" set primitives origins to x/y/z? Currently AFAIK it does nothing.
(2017-02-21, 15:31)Philippe Hurbain Wrote: [ -> ]Works great so far Wink
"Set x/y/z" only works with vertices at the moment.
But, what you want is a new feature! Smile I created issue #504 for your request.
Really love the new features of this release... (OK, I asked for them Wink )
Something I miss is a tool that creates vertex on line intersection (I generally start a part by drawing a skeletton of lines, and need to know where they meet). Currently I duplicate the lines, move them, create surfaces on them and use isecalc. Feasible, but a tad tedious...
(2017-02-24, 19:09)Philippe Hurbain Wrote: [ -> ]Something I miss is a tool that creates vertex on line intersection ...
Me too...
(2017-02-24, 19:09)Philippe Hurbain Wrote: [ -> ]Something I miss is a tool that creates vertex on line intersection...
I am working on it! (issue #505)
Oh well... I'm tired... Sad After I did some testing, I thought that there was an implementation mistake whithin the new local/global rotation and scaling feature...
Local rotate and scale did not work as I expected, but I did not realize that I simply forgot to modify the pivot point during the regression test (everything is as it should be).
You can see that I hit the panic button too early when you take a look at the history of issue #505 Wink I turned literally a bug into a feature Big Grin
Today I closed issue #504, too ("Set x/y/z" should set the origin of subfiles and primitives to x/y/z).
Great Wink
Yes it works as expected, but indeed it's easy to forget something... eg. forget to copy paste before mirroring, check the global/local method, use the right axle (maybe it would be interesting to display somewhere the local directions? currently I switch to move mode -but often forget!- just to get the arrows). Oh well, it's a feature rich tool problem Big Grin
I just had the idea to initialise the pivot point coordinates with the manipulator position (local mode only).
...and implemented it in five minutes.
(2017-02-25, 19:40)Philippe Hurbain Wrote: [ -> ]maybe it would be interesting to display somewhere the local directions? currently I switch to move mode -but often forget!- just to get the arrows.
I could always display the manipulator while the dialog is open...
...and... without further ado:
I implemented it in two minutes (issue #508).
Awesome!
Any suggestion where to store LDPE on Linux Mint 17.3?
(2017-02-26, 6:44)Philippe Hurbain Wrote: [ -> ]Awesome!
Version 0.8.29 is complete.
(2017-02-28, 20:05)Willy Tschager Wrote: [ -> ]Any suggestion where to store LDPE on Linux Mint 17.3?
I just created a folder within my home folder.
It is sufficient that LDPE can read and write within that folder.
For windows I will write some special code to support the "AppData" folder in the future.
I know that there is a feature request to store LDPE in the "Program Files" folder, but I have to work on other issues first.
Got a minor, low priority request: make the menu bar tools button (currently a teeny down arrow) a normal sized "Tools..." button. My mind knows it's there, but my finger so often hits the merge/split button instead!
(2017-03-01, 8:11)Philippe Hurbain Wrote: [ -> ]Got a minor, low priority request: make the menu bar tools button (currently a teeny down arrow) a normal sized "Tools..." button. My mind knows it's there, but my finger so often hits the merge/split button instead!
Done! (issue #511)
Suggestions for a desktop icon entry in order to run the shell script from the desk? This one doesn't work:
[Desktop Entry]
Comment=
Terminal=true
Name=LDPE
Exec= sh /home/willy/LDPE/run.sh
Type=Application
What about integrating Ytruder? Sometimes miss it, and shouldn't be very difficult...
(2017-03-17, 16:11)Willy Tschager Wrote: [ -> ]Suggestions for a desktop icon entry in order to run the shell script from the desk? This one doesn't work:
[Desktop Entry]
Comment=
Terminal=true
Name=LDPE
Type=Application
I would still appreciate some hints from the Linux wizards out there.
(2017-04-21, 6:23)Willy Tschager Wrote: [ -> ]I would still appreciate some hints from the Linux wizards out there.
  1. Adjust the path within the txt-files to match your installation directory (where the ".jar" file is located, Path=..., e.g. /home/username/LDPartEditor)
  2. Remove the ".txt" file ending (ldpe.desktop.txt -> ldpe.desktop and ldpeupdater.desktop.txt -> ldpeupdater.desktop)
  3. Copy the ".desktop" files into the /home/your_user_name/.local/share/applications folder
  4. Copy the ".png" files into the /home/your_user_name/.local/share/icons folder
Sometimes, deselected elements are re-selected when selecting a subpart.
Reproducing scenario:
- Select a few simple elements (lines and/or surfaces)
- Press Esc to deselect them
- change to subfile selection mode
- click on a subfile to select it.
all (but last one) simple elements are now selected with the subpart.
Wish of the day (conveniency)
As a user, I'd like to have a "select all types" and a "select none" check box along with select vertices/lines/triangles etc
With these buttons I can - for example - quickly select all condlines ("select none" then "condlines") then come back to normal usage ("select all types"). I have a similar feature in my electronics CAD program, and it proves very convenient.
Another issue with select filter... Even if an element is filtered out, clicking on it still selects it. Generally this is only mildly annoying, but it becomes a real pain when trying to select edge lines and nearby (invisible) condlines get selected at the same time, even if condlines are unchecked in selection filter.
(2017-05-22, 14:52)Philippe Hurbain Wrote: [ -> ]Another issue with select filter...
Yes,
How do I select only one, single vertex on a surface, when I have two, or more, adjacent surfaces.
I want to grab that single vertex, and move it away from the other one.
As a user I want to select a single vertex in the Text Editor, click on Show Selection in 3D view, and move that vertex in the 3D Editor with the Manipulator.
Workaround:
Select a quad in the 3D Editor, look at it in the Text Editor, Select the vertex in the 3D Editor, and let the Sync Edit show which vertex it is.
Turn of both Move Adjacent (in 3D) and Sync Edit (in Text Edit) and edit the vertex in the Text Editor. Grab it in 3D Edit and move it.
Yeah, I have this problem too from time to time. My workaround is to move the entire surface, then move the vertex I want to modify, then replace the surface (with the vertex now disconnected from neighbour elements).
(2017-04-22, 14:18)Nils Schmidt Wrote: [ -> ]
Did, but who do I get them on the desktop? I copied it from the applications folder to the Desktop but it doesn't show up even if I remove the hidden feature. Recopying tells me that the file is already there.
PS. Why is there such a huge difference on the primitive icons? On linux you can tell what prims are shown while you cannot at all on Windows?
[attachment=2781]
(2017-06-05, 11:06)Willy Tschager Wrote: [ -> ]Why is there such a huge difference on the primitive icons? On linux you can tell what prims are shown while you cannot at all on Windows?
Hi Willy,
I would like to see how it looks on your Windows system, too. Your screenshot looks normal.
There are two buttons below the primitive icon area: plus (+) and minus (-) to enlarge or shrink the primitive icons.
Cheers
Nils
Now I know what's wrong. The windows version shows a frontal view and I have no idea how to rotate it to 3D.
[attachment=2795]
(2017-06-14, 10:41)Willy Tschager Wrote: [ -> ]Now I know what's wrong. The windows version shows a frontal view and I have no idea how to rotate it to 3D.
Click in the primitives preview window. Then you can rotate them exactly the same way as you rotate model in main window.
a) Click in the primitives preview window. Then you can rotate them exactly the same way as you rotate model in main window (middle mouse button or 'M' key). You can use the scroll wheel or the right mouse button to scroll and ctrl+scroll wheel zooms in/out.
b) I created an issue (#542) for a tooltip
c) This is not the default behaviour anymore (#422). If you reset your settings on Windows, you'll see the same view .
Hope this helps :)
(2017-05-14, 9:13)Philippe Hurbain Wrote: [ -> ]Sometimes, deselected elements are re-selected when selecting a subpart.
I was able to fix this issue (#536).
(2017-06-15, 13:26)Nils Schmidt Wrote: [ -> ]
Good new, was a pretty annoying one (often I didn't noticed and got duplicated things...)
I installed Linux Mint 18.3 Sylvia and the above starter seam not working anymore. My paths are:
java: /usr/share/java
LDPartEditor.jar: /home/willy/LDPartEditor
[attachment=3263]
Any ideas?
(2018-09-19, 17:56)Willy Tschager Wrote: [ -> ]I installed Linux Mint 18.3 Sylvia and the above starter seam not working anymore. My paths are:
LDPartEditor.jar: /home/willy/LDPartEditor/
Create a new launcher (right click / context menu on desktop) with this command:
/usr/share/java/bin/java -Djava.library.path='/home/willy/LDPartEditor/natives/' -jar /home/willy/LDPartEditor/LDPartEditor.jar
(2018-11-30, 20:27)Nils Schmidt Wrote: [ -> ]Move your config.gz file to /home/willy/config.gz
and create a new launcher (right click / context menu on desktop) with this command:
Keep please in mind that you're talking to a very dump linux user. Where do I find the config.gz file?
(2018-12-01, 11:06)Willy Tschager Wrote: [ -> ]Keep please in mind that you're talking to a very dump linux user. Where do I find the config.gz file?
I included an unnecessary step... The config.gz file contains your user settings for LDPartEditor.
It does not exist on a fresh installation! Sorry for the confusion...
