2017-02-17, 22:01
Hey,
after I released a new version of LDPatternCreator (LPC) in the beginning of this month, it is now time for the "bigger brother" LDPE :)
Changelog:
(4 new features and 4 bug fixes)
What will the next release 0.8.29 deliver? Bug fixes, more header validation features, usability improvements...
Please note that this software is in the beta stage. Although, LDPE 0.8.28 was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Changelog:
- ...override colour 16.
- ...set the distance meter length in the selection window.
- ...constrain "Merge to Nearest..." to operate in a fixed direction (X/Y/Z).
- ...choose between world axis X/Y/Z and manipulator axis X/Y/Z for transformation tools (translate / rotate / scale selection / set selection X/Y/Z)
- The colour value for colour 16 was not read from LDConfig.ldr
- If you split a distance meter you got two normal edge lines instead of two distance meters.
- LDPE did not complain about some duplicated lines (TYPE 2, 3, and 4).
- "Local" mode for the distance meter showed sometimes wrong values for dx / dy / dz
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
