LDraw has a (in my opinion kinda weird) standard for patterned part numbering. However, sites like Rebrickable and Brickset nowadays scrape a lot of information from Lego itself. This information also includes the design id for patterned parts. Like every brick, every pattern has its own unique design-id.
For example,
this part has the design-id 25660 and
this part has the design-id 32734.
Would it be a good idea to change the patterned-part numbering of LDraw parts (for future parts obviously, not for current parts) to use the design-id when available?
(2017-02-08, 7:52)Merlijn Wissink Wrote: [ -> ]LDraw has a (in my opinion kinda weird) standard for patterned part numbering. However, sites like Rebrickable and Brickset nowadays scrape a lot of information from Lego itself. This information also includes the design id for patterned parts. Like every brick, every pattern has its own unique design-id.
For example, this part has the design-id 25660 and this part has the design-id 32734.
Well, often (or should I say sometimes... or maybe rarely?) part author submits both the part with LDraw style part number AND an alias with LEGO design number. LDraw numbering has one big benefit: all patterns on the same shape share the same root number, making easy to locate all patterned versions, while with LEGO design this relationship is lost.
See for example
http://www.ldraw.org/cgi-bin/ptdetail.cg.../26530.dat /
http://www.ldraw.org/cgi-bin/ptdetail.cg...118p02.dat
There is also the problem of torsos and legs, since LEGO design number is for torso+arms+hands or hips+legs combos...
