2017-01-27, 17:04
Trevor,
As you are aware, I've been working on trying to improve the quality of the POV-Ray rendering in LPub3D. The first step was to implement customized lighting. That resulted in a major improvement, but I was still running into an issue that I felt needed to be fixed: many images had dark gray artifacts on curved surfaces that I couldn't get rid of simply by changing the light definitions.
I think I have finally figured out source of the problem.
When LPub3D invokes L3P, it specifies a camera angle (field of view) of 0.01 degrees (-ca0.01). I assume that you work backward from there to determine the camera distance (-cg0,0,{large number}) in order to end up with a properly-sized image. My guess is that you are using a small field of view and a long distance to minimize apparent distortion caused by different parts of the model being different distances from the camera. I think -ca0.01 is quite a bit of overkill and is leading to the artifacts I mentioned.
I have modified my program that inserts custom lighting to also modify the -ca and -cg parameters. I am currently using a 10-degree FOV and calculating the corrected camera distance. I'm quite pleased with the results. The resulting renders are much closer to the quality I get when using LDView to manually generate the POV file.
Can I suggest that you try larger FOV values to when calling L3P to improve the quality of the resulting render while still minimizing apparent distortion? Perhaps this could be a value set by the user in Preferences.
I've also been working on a way to have LPub3D use LDView for exporting POV files. I've had some moderate success, but it's pretty klugey. Since I figured out the L3P issue, there is no longer the same level of urgency to pursuing this route.
Thank you.
Kevin
Thank you.
Kevin
