Hi all!
I'm Miriana, I'm a lego fan aholic enthusiasitc...^^
I use mlcad, now I'm making "millenium falcon" from star wars (mod. 7778) and I need help with a part.
I need to "curve" Corrugated Pipe 112Mm as flexible part to put on model (as shown on attached image).
Can you help me?
Thanks in advance.
Hello,
When you are using MLCAD the best option to work with bent parts is LSYNTH.
Actually it should be in your installation if you used the AIO Installer from the LDraw Website.
Here is a tutorial of its use:
http://www.holly-wood.it/lsynth/tutorial-en.html
Another Option is LDCad, a fairly new CAD program where communication pertaining to its features is very active in this forum.
Gerald
(2017-01-26, 13:45)Philippe Hurbain Wrote: [ -> ]Quote:Another Option is LDCad, a fairly new CAD program where communication pertaining to its features is very active in this forum.
LDCad (highly recommended!) is here: http://www.melkert.net/LDCad - It is also included in LDraw All in One installer.
A tutorial video showing flexible parts usage is here: https://www.youtube.com/watch?v=Peu5yqD2iAo
Minor note: I did the pneumatic's wrong in that clip, but seemingly no-one noticed or cared
(2017-01-26, 20:11)Miriana Wrote: [ -> ]I've solved trouble so...
Not sure if you mean you used LSynth, but this is how you would do it in LDCad
attachment=2692]
ps: It is probably best to use the LQ version of the hose.
