I found a new theme for the forums that might be liked better by some. It's a bit less white and more grey like the old forums software. I still have to do some modifications to it (e.g. some images are broken) but you can give it a test drive.
- Go to User CP
- In the sidebar under "Your Profile" click "Edit Options"
- On the right under "Other Options" change "Board Style" to "stb"
- Click Update Options
Please let me know what you think and if you notice any broken images which seems to be the biggest issue right now.
(2017-01-13, 4:17)Orion Pobursky Wrote: [ -> ]Please let me know what you think and if you notice any broken images which seems to be the biggest issue right now.
Personnaly I kind of prefer "regular" theme - especially the explicit blue text for links. With the new theme you have to mouse over to discover -by chance- that there is a link...
Otherwise, the search box is missing (as well as banner/link to LDraw website)
(2017-01-13, 4:17)Orion Pobursky Wrote: [ -> ] I found a new theme for the forums that might be liked better by some. It's a bit less white and more grey like the old forums software. I still have to do some modifications to it (e.g. some images are broken) but you can give it a test drive.
- Go to User CP
Would you please so kind and add the "purge spammer" button to the new theme?! ;-)
(2017-01-17, 13:39)Max Martin Richter Wrote: [ -> ]Would you please so kind and add the "purge spammer" button to the new theme?! ;-)
I'm confused on what you are referring to.
(2017-01-13, 12:04)Philippe Hurbain Wrote: [ -> ] (2017-01-13, 4:17)Orion Pobursky Wrote: [ -> ]Please let me know what you think and if you notice any broken images which seems to be the biggest issue right now.
I think I might "bleed" some of the color scheme into the default theme. There's also functionality to have different "color only" themes with the same underlying html.
(2017-01-17, 23:30)Orion Pobursky Wrote: [ -> ] (2017-01-17, 13:39)Max Martin Richter Wrote: [ -> ]Would you please so kind and add the "purge spammer" button to the new theme?! ;-)
Nevermind, I figured it out. It doesn't show up with users who have greater than 10 posts.
That said, I don't think the new theme will stick around for very long as I found a way to "reskin" the main theme.
(2017-01-18, 3:35)Orion Pobursky Wrote: [ -> ] (2017-01-17, 23:30)Orion Pobursky Wrote: [ -> ]I'm confused on what you are referring to.
Strange, I had a spammer with exactly one post. So I decided to switch the theme to the old one temporally.
