2016-12-31, 12:24
Hello,
I would like to use the last day of this year to publish a new version of LDPE
...and I thank you very much for this award! Its my pleasure to play around with LDraw and to develop highly useful tools for
the community. I am an agile software developer. I am a big fan of extreme programming, kanban and kaizen.
LDPC and LDPE are perpetual beta versions. They will stay at the development stage for an indefinite period of time.
Changelog:
(3 new features and 7 bug fixes)
What will the next release 0.8.28 deliver? Bug fixes, more header validation features, usability improvements...
Please note that this software is in the beta stage. Although, LDPE 0.8.27 was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Changelog:
- ...choose whether or not "Merge to Nearest Edge" splits the edge on merged vertices.
- ...limit unrectifier to only inline rect primitives (hold Ctrl and press the unrectifier button).
- ...adjust the direction of the manipulator to the direction of an edge. I changed the behavior of "Move Manipulator to the Nearest Edge"!
- Fixed an endless loop on the first start (affected 0.8.26 only).
- Rectifier added the same edge line into two adjacent rectangle primitives.
- Toggle comment / TEXMAP didn't adjust the text selection.
- The new render engine is now optional. Its automatic hardware detection was broken.
- When you inserted a protractor, the order of the vertex triplet was not deterministic.
- Unrectifier inserted an extraneous empty lines where rects were previously.
- The quick fix of "invalid use of 'BFC INVERTNEXT' / Flat subfile" only removed the BFC INVERTNEXT statement. It should also invert the direction of the flat subfile in flat direction to keep the same BFC winding.
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
