2016-12-04, 13:42
2016-12-04, 13:48
![[Image: 42057.png]](http://www.brickshelf.com/gallery/Philo/SetModels/Set42057/42057.png)
Download MPD (OMR compliant)
Known errors: No stickers.
Done with LDCad 1.6 alpha 4
Edit: now with anniversary beam
2016-12-08, 10:01
![[Image: 42058.png]](http://www.brickshelf.com/gallery/Philo/SetModels/Set42058/42058.png)
Textures for the ramp (to be placed in your LDraw\parts\textures folder) are available here - direct links (1) (2).
2016-12-08, 20:34
The download link is pointing to the helicopter, not the bike.
2016-12-08, 21:47
(2016-12-08, 20:34)Magnus Forsberg Wrote: [ -> ]The download link is pointing to the helicopter, not the bike.Thanks, Magnus. Corrected!
2016-12-15, 16:14
2017-01-31, 9:17
2017-02-01, 11:08
2017-02-02, 8:17
![[Image: 42059.jpg]](http://www.brickshelf.com/gallery/Philo/SetModels/Set42059/42059.jpg)
Done with LDCad 1.6 beta 1
2017-02-02, 14:46
![[Image: 42065.jpg]](http://www.brickshelf.com/gallery/Philo/SetModels/Set42065/42065.jpg)
Edit: moved to another Brickshelf folder
2017-02-10, 14:12
2017-02-10, 22:58
There seems to be something wrong at the front fork. A pin is going through the #2 180° connector. I think the connector must be rotated by 90°.
(I'll delete this post, when the problem is confirmed or solved)
2017-02-11, 7:39
(2017-02-10, 22:58)Max Martin Richter Wrote: [ -> ]There seems to be something wrong at the front fork. A pin is going through the #2 180° connector. I think the connector must be rotated by 90°.Thanks, Max, mpd now corrected !
2017-02-11, 12:25
![[Image: 42066_-_air_race_jet.jpg]](http://www.brickshelf.com/gallery/Philo/SetModels/Set42066/42066_-_air_race_jet.jpg)
Done with LDCad 1.6 beta beta 2 preview
Variant with retracted landing gear: Download MPD (OMR compliant)
...getting proper alignment of all those linkages was not a simple job...
2017-02-24, 13:50
2017-02-25, 17:06
(2017-02-11, 7:39)Philippe Hurbain Wrote: [ -> ](2017-02-10, 22:58)Max Martin Richter Wrote: [ -> ]There seems to be something wrong at the front fork. A pin is going through the #2 180° connector. I think the connector must be rotated by 90°.Thanks, Max, mpd now corrected !
Missed your post. Do you plan to update the picture, too?
2017-02-26, 10:34
And all the files are now on the OMR. Nice work on all those Technic sets!
2017-02-26, 14:36
(2017-02-26, 10:34)Merlijn Wissink Wrote: [ -> ]And all the files are now on the OMR. Nice work on all those Technic sets!
2017-09-06, 15:32
2017-09-06, 20:09
![[Image: 42068_-_airport_rescue_vehicle_1.png]](http://www.brickshelf.com/gallery/angmarec/Technic/42068_-_airport_rescue_vehicle_1.png)
2017-09-07, 5:12
Nice! Thanks, Stan
2017-10-10, 12:28
2017-10-24, 8:56
2017-10-24, 19:25
I think you forgot the remote, and I wouldn't mind an animated version
2017-10-24, 19:44
(2017-10-24, 19:25)Roland Melkert Wrote: [ -> ]I think you forgot the remote, and I wouldn't mind an animated versionIndeed. Remote easy to add, animation...
2017-10-25, 8:58
(2017-10-24, 19:25)Roland Melkert Wrote: [ -> ]I think you forgot the remote, and I wouldn't mind an animated versionAdded missing remote!
Speaking of LDCad animations, have you seen this VEX clock animation made by Andreas Dreier? https://www.youtube.com/watch?v=SDw9dYMzygY
2017-10-25, 15:05
(2017-10-25, 8:58)Philippe Hurbain Wrote: [ -> ]Speaking of LDCad animations, have you seen this VEX clock animation made by Andreas Dreier? https://www.youtube.com/watch?v=SDw9dYMzygY
Very nice, I've always wanted to do a clock animation. LEGO should do a clock technic set as I'm not much of an designer myself.
2019-03-29, 12:07
(2017-02-24, 13:50)Philippe Hurbain Wrote: [ -> ]
As a showcase of what LPub3D can do in combination with the LDraw tools the model with full instructions can be found here.
The goal was to stay as close to the original instructions as possible using many LDraw/LPub3D techniques.
https://sites.google.com/view/workingwit...d/showcase
2019-03-29, 15:10
(2019-03-29, 12:07)Jaco van der Molen Wrote: [ -> ]As a showcase of what LPub3D can do in combination with the LDraw tools the model with full instructions can be found here.Awesome work, Jaco! A good example is worth many tutorials
