2016-11-20, 19:38
Sorry, but version 0.8.26 is now marked as unstable / impossible to use.
I reverted all download paths (github / sourceforge) back to version 0.8.25.
J.C. Tchang found a bug, which triggered an infinite loop on the first start.
I apologize for any inconvinience! :/
Greetings,
here is version 0.8.26 with 8 bug fixes and 4 enhancements (including a completely new and fast render engine)!
You can see if the new engine is active when you take a look at the window title: "LD Part Editor 0.8.26 (OpenGL 3.3)"
In case of a hardware or software incompatibility it would be written as "LD Part Editor 0.8.26 (OpenGL 2.0)".
I did a few improvements here and there, too, which I do not describe in detail.
Unfortunately, I have to drop the 32bit support for a moment.
Changelog:
(4 new features and 8 bug fixes)
What will the next release 0.8.27 deliver? Bug fixes, more header validation features, usability improvements...
Please note that this software is in the beta stage. Although, LDPE 0.8.26 was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Greetings,
Changelog:
- ...benefit from a brand new render engine (thanks to the power of OpenGL 3.3, which makes better use of the GPU).
- ...activate "Smooth Shading" (requires the new render engine).
- ...benefit from a faster program start.
- ...benefit from better performance for "Show All".
- Toggle comment / TEXMAP didn't adjust the text selection.
- Sometimes a time-consuming selection with the selection rectangle did select nothing.
- Background Image: "Previous" and "Next" buttons skipped images.
- Edger2 wrongly added condlines in the middle of slightly warped quads
- Edger2 put condlines/edge lines between surfaces and... protractors.
- Double click doesn't select the last character of a value if it was at end of line.
- !TEXMAP PLANAR: Wrong winding for CCW faces (with INVERTNEXT)
- Fixed a rare exception regarding directory I/O
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
