(2016-11-15, 16:34)Philippe Hurbain Wrote: [ -> ]Is there an easy way to convert old forum URL in order to find again content? (eg. http://forums.ldraw.org/read.php?19,1161...#msg-11619)
The conversion script should have taken care of that for the forums. As far as manually saved links, the "msg-#" is the post number and the smaller of the last 2 comma separated numbers in the URL is the thread id. The generic format is:
http://forums.ldraw.org/thread-<thread id>-post-<post number>.html#pid<post number>
Just replace <thread id> and <post number> with the appropriate number.
(2016-11-15, 17:19)Magnus Forsberg Wrote: [ -> ]Nope.
That doesn't work.
Thanks. I was riffing off my memory which apparently sucks
I guess I can set up a rewrite rule for that.
(2016-11-15, 21:30)Orion Pobursky Wrote: [ -> ]I guess I can set up a rewrite rule for that.
Have you found the correct translation formula yet?
(2016-11-21, 21:11)Magnus Forsberg Wrote: [ -> ] (2016-11-15, 21:30)Orion Pobursky Wrote: [ -> ]I guess I can set up a rewrite rule for that.
Not quite. I need to do some more mod_rewrite research.
(2016-11-24, 21:06)Orion Pobursky Wrote: [ -> ]Should work now.
Seems to work fine indeed - Thanks!
