Is there a tool available that can draw a curve or circle with a given radius, and then approximate that curve with bricks? Thanks.
[edit]
I recalled that MLCad has a mosaic generator that can take a bitmap image as input. But I haven't found a good tool to draw the circles.
1. Paint.NET output isn't symmetrical in my tests.
2. GIMP draws the circles too thick. I want them only 1px thick.
3. This tool is pretty good, but I don't know how to get rid of the gray lines.
https://donatstudios.com/PixelCircleGenerator
4. Ditto.
http://www.mineconics.net/
I have a copy of Paint Shop Pro somewhere. I will need to dig it out of storage.
(2016-11-01, 2:57)Michael Horvath Wrote: [ -> ]Is there a tool available that can draw a curve or circle with a given radius, and then approximate that curve with bricks? Thanks.
[edit]
3. This tool is pretty good, but I don't know how to get rid of the gray lines. https://donatstudios.com/PixelCircleGenerator
4. Ditto. http://www.mineconics.net/
If all you want is a paint program that can draw symmetrical bitmap curves, you can use MS Paint. Hold down Shift while drawing an oval to get a circle, and unlike Paint.NET, MS Paint draws symmetrical circles (as far as I can tell). Blow up the resulting image if you need to (without any smoothing) to make it pixellated. Do your actual drawing at 400%-800% zoom to better see what you're doing. (Note that I'm using MS Paint in Windows 10 with Anniversary update, but I think it has behaved this way pretty much forever.)
(2016-11-01, 4:33)Travis Cobbs Wrote: [ -> ] (2016-11-01, 2:57)Michael Horvath Wrote: [ -> ]Is there a tool available that can draw a curve or circle with a given radius, and then approximate that curve with bricks? Thanks.
[edit]
Thanks! I was able to create the attached image in case someone needs it. It is scaled up 10x for clarity. Normally, it is 32x32px which is the same size as a baseplate according to MLCad's mosaic generator.
Mike
[edit]
I ended up using GeoGebra to create an exact sketch of what I want, then reproducing the sketch in POVray and rendering at a small scale and without antialiasing. For instance, I've attached an (enlarged 10x) curvy road image to this post.
Eventually I would like to write a script that generates custom unofficial road models that follow splines and other shapes. (I did this for POV-Ray already, but details like road stripes are harder to pull off in LDraw.)
Mike
[edit]
It seems MLCad's mosaic generator is not converting my image exactly. There are missing bricks, and extra bricks where there shouldn't be any. I need to find a different program.
lmao chatgpt generated text geeeeeeeeeg
(2024-08-08, 21:28)Jeff Jones Wrote: [ -> ]lmao chatgpt generated text geeeeeeeeeg
Spammer banned and posts deleted. Us admins have a "nuke button" for such things.
[edit]
The tool I used before is:
https://minecraftcirclegenerator.cc — it mostly does the job, but there's one dealbreaker: when I change the scale, previously marked blocks vanish. I can't believe such a simple feature is so hard to get right
[edit]
I think this tool can meet your requirements:
https://circle-generator-minecraft.com
