2016-09-27, 22:12
Hey,
here is version 0.8.25 with 8 bug fixes and <3 enhancements!
Unfortunately, I have to drop the 32bit support for a moment.
Currently, I implement a new render path and I write some content for the wiki/manual.
The last build failed on Windows XP (32-bit) and I had no time to track down the issues, yet.
But yeah... I want to keep the release train rolling
Changelog:
(3 new features and 8 bug fixes)
What will the next release 0.8.26 deliver? Bug fixes, more header validation features, usability improvements and maybe a new fast render path (I don't know how much time it will need)...
Please note that this software is in the beta stage. Although, LDPE 0.8.25 was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Changelog:
- ...double click on a decimal number to select the whole value, including integer part, decimal part, decimal separator and minus sign if any (Text Editor).
- ...see that all three coordinates are unchecked when the coordinate dialog opens. The coordinates where you type in a value will become active (3D Editor, Merge/Split -> Set X/Y/Z).
- ...benefit a little from a faster draw method for lines and condlines.
- Flipper: Condlines were "not recalculated" so their control points were wrong after flipping.
- The calculation for quad (and triangle) collinearity detection was wrong
- Last added elements were not saved (3D Editor).
- Wrong winding colour in some rare cases (CW: clockwise winding only)
- Merge/Split -> Set X/Y/Z did not work sometimes
- A ConcurrentModificationException occured in the process which hides condline control points
- A ConcurrentModificationException occured during normal calculation for the LDraw Standard Mode
- There were non-threadsafe method calls within the logger class.
- Download the zip-Archive
- On linux, you have to excecute the shell script "run.sh" to start LDPE.
- On linux, you have to excecute the shell script "update.sh".
- Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4]
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
- For a faster start, LDPartEditor and the LDraw™ library should be installed on a SSD.
java -d64 version
