2016-09-03, 11:07
Hey,
here is version 0.8.24 with 4 bug fixes and 3 enhancements.
...I am writing content for the wiki/manual now.
Changelog:
(3 new features and 4 bug fixes)
What will the next release 0.8.25 deliver? Bug fixes, more header validation features, usability improvements...
Download the zip-Archive
Extract the archive content to the location of your choice
On windows, double-click "run.bat" to start LDPE.
On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, LDPE 0.8.24 was tested, there are already known issues for this release. There is a potential risk of data loss.
On windows, double-click "update.bat" to search for updates.
On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
Java Runtime Environment (JRE) 1.8
OpenGL 2.1 compatible Graphics Card
Operating System (32/64bit): Windows [XP; Vista; 7 or newer], Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
CPU: Multicore-Processor e.g. Intel Core 2 Duo or AMD Athlon II (>2.0Ghz)
RAM: 4GB
Video-Memory: 512 MB
Free Disk Space: 100 MB
Recommended Requirements:
Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
CPU: Multicore-Processor with 4 cores (or more)
RAM: >4 GB
Video-Memory: >=1 GB
Free Disk Space: 512 MB
java -d64 version
Changelog:
- ...use per-component rounding (X, Y, Z) instead of the per-vertex rounding (useful for patterns on slopes).
- ...use the metadata dialog (AKA "header dialog") on the text editor, too.
- ...benefit from a faster program start.
- It was not possible to activate "Create a new conditional line..." via a shortkey.
- The new LDU to stud converter did not round correctly (20 LDU = 1 stud, rounded to one decimal place)
- The Merge/split->Set X,Y,Z window appears only with a single vertex selection, it no longer works on a multiple selection (eg. to snap a selection on a plane).
- The error message "Invalid use of 'BFC INVERTNEXT' / Flat subfile" got duplicated.
RAM: 4GB
RAM: >4 GB
java -d64 version
