2016-08-29, 11:51
Hey,
release 0.8.23 comes with 6 bug fixes and 8 enhancements.
...I am going to write more content for the wiki/manual now.
Changelog:
(8 new features and 6 bug fixes)
What will the next release 0.8.24 deliver? Bug fixes*, more header validation features, usability improvements...
* oh dear..., I still need to reproduce some errors...
System Requirements:
Minimum System Requirements:
Changelog:
- ...convert a unit to stud (20 LDU = 1.0 stud, rounded to one decimal place).
- ...access all context menu features from somewhere else, too.
- ...use the "Expand Area" buttons to "toggle" the divider position between the text and the 3d editor.
- ...use more dynamic context menus.
- ...benefit from the fact that there are bigger previews for the primitive area by default.
- ...benefit from the fact that "Text on the right / 3D on the left" is now the default window setting.
- ...see the stud logos on the upper left view when you use the PartReview tool.
- ...benefit from an asynchronous file header check (performance improvement / preparations for more validation features).
- Deleting all text lines from a file with the text editor could sometimes freeze LDPE.
- The PartReview tool did not close+reload already opened "duplicated" files.
- When PrimGen2 opened the file in the 3D editor, the corresponding file tab was not selected.
- The menu key (from the keyboard) did not work on the file tree.
- The menu key (from the keyboard) did not work on the 3D view.
- Wrong singular / plural use for the word "duplicate".
- Download the zip-Archive
- Java Runtime Environment (JRE) 1.8
- RAM: 4GB
- Video-Memory: 512 MB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
- RAM: >4 GB
- Video-Memory: >=1 GB
- Free Disk Space: 512 MB
java -d64 version
